Kaspersky sucks with regards to using it on a Media Center PC. It simply wreaks havoc with everything. Your best bet is to uninstall it and download Microsoft Security Essentials. It should provide sufficient protection and won't interfere with your HTPC operations.Originally Posted by chungsters
Have had major problems with my Ceton InfiniTV 4 and Kaspersky Anti/Virus...Long story short. I had to remove my A/V. Re-installed InfiniTV set-up. However, when Media center scans for the tuners it would only find 1. If you tried to record media center would say no tuners found. It took me 2 months to figure this out. So to save the rest of you the heartache. This is how I had to fix it. After you remove the A/V you must also remove the Infiniti TV entry in Programs ( Add/ Remove Programs). Also remove the network driver under system properties. Re-boot. download a fresh copy of the installation set-up form Ceton and install.Run throught the set-up again and you should see all 4 tuners return when Media Center scans for new tuners. This has solved all my recording issues and working for several weeks so far. Hope this can help someone else.
