AVS › AVS Forum › Audio › Receivers, Amps, and Processors › How do I verify - or debunk - the claims of The Upgrade Company?
How do I verify - or debunk - the claims of The Upgrade Company? - Page 48
post #1411 of 1596
Originally Posted by craig john View Post
Actually, the *best* way to nullify the effect of the switch would be to send it to TUC to be "upgraded". If DS could work his "magic" on it, it could be used in a blinded test without any impact on the test. In fact, it might just improve the sound for both DUT's. Either way, DS could no longer use it as the "reason" the blinded test was suspect. It would no longer be "controversial."
J/K Kal!
Craig
From my cold dead hands.
post #1412 of 1596
Originally Posted by pepar View Post
I'm not so sure Schulte does either. My money is on him knowing it's BS and throwing that out as a red herring to muddy the waters ... odd mixed metaphor, but that's what I think.
Jeff
You're completely right. Nobody should kid himself about this--DS and the rest of the subjectivist believers will grab onto anything they can think of to try to "invalidate" a DBT. If the offer had been made to do a manual cable swap, they would have thought up an objection to that -"too much time between selections", etc (of course, that objection is NEVER EVER brought up with sighted comparisons--ONLY with a DBT). It's all part of their game of avoiding objective comparisons, because they KNOW such comparisons won't support their claims.
post #1413 of 1596
Just to be clear, the current test was NOT a "DBT" or Double Blind Test. It was an "SBT" or Single Blind Test. The difference is *potentially* significant.
Craig
post #1414 of 1596
Craig
I'm a little confused about what you mean by "the current test". The test I read about involving Jeff and Rich used an ABX protocol (as I understand it), which would make it double blind. Besides, it makes no sense to say that people are better at identifying which is which in a DBT than a SBT.
post #1415 of 1596
Right.
It is single-blind because the operator of the test knew the identity of devices in each trial. It would have been possible to make it double blind but, considering the resources available, that would have been cumbersome.
post #1416 of 1596
Originally Posted by Kal Rubinson View Post
Right.
Ah, ok. I misunderstood the conditions. It stands to reason, though, that Jeff or Rich wouldn't have done better if it was double blind.
post #1417 of 1596
A "Double blind test" means that both the tester and the testee are blinded to the DUT. In a "Single blind test", only the testee is blinded. In a DBT, the person operating the switch would not know which DUT was in use for any given setting of the switch. The "significant difference" is that there is the potential for the person operating the switch to provide some subliminal or greater indication as to which device is under test. In the test performed by Jeff, Dennis and Rich, the person operating the switch was not blinded to the DUT, only the listener was blinded; IOW, it was an SBT. Dennis operated the switch for Jeff and Rich. I believe Jeff operated the switch for Dennis. I don't know if the preliminary test results were shared with other listeners before the subsequent tests. I believe there was a screen between the tester and the testee. Still, verbal and non-verbal communication between the tester and testee could give some feedback that could *potentially* influence he results. I'm not saying any of this happened in the current test. I'm just saying it *could* have happened.
Here is an article about the potential pitfalls of performing blind listening tests:
http://www.audioholics.com/buying-gu...listening-test
The "ABX" part of the test is not part of the definition of the "blinding" portion of the test. The ABX definition refers to the identification of X as being the same as A or B. This obviously needs to be done blind for the listener. However, there is no requirement for the switch operator to also be blind. To make the test most rigorous, the test would be a DBT, ABX test. However, that is not how this current listening test was set up.
Craig
post #1418 of 1596
I have noticed that many times (including from audio manufacturers who really should know better) DBT is used in place of SBT far too often, and many do not know the difference.
Craig and Kal explained it.
post #1419 of 1596
Craig gave an excellent explanation. I was already aware of what he explained, I just didn't realize that the person operating the switch knew which was which. I had assumed that the ABX device was similar to this one.
post #1420 of 1596
I agree - a great job on your explanation Craig. I also respect that you've shared your opinion on the switch (you don't think it caused any degregation), and at the same time, recognizing that it's only an opinion until it a comparison can be made with and without the switch. A very fair point of view.
Dave
post #1421 of 1596
This is your opinion, an assumption, and not true in my case.
Dave
post #1422 of 1596
Originally Posted by thezaks View Post
Jeff,
You mention that the switch is the closest thing to manually swapping the cables - how do you know that? And, "closest thing" is not the "same thing".
The switch used is a passive device. To all intents and purposes it is the same as swapping the cables by hand.
post #1423 of 1596
DS and the rest of the subjectivist believers will grab onto anything they can think of to try to "invalidate" a DBT....
Robert,
I don't believe this is true at all. I may not speak for David Schulte, but I do speak for myself. There's nothing wrong with an SBT or DBT.
(I don't believe there's anything wrong with the Zektor switch, either. DS & Zaks think differently, so I'll leave them to argue that one. I'm not 100%, but I'm pretty sure that's the red herring.)
The problem I have is with ABX testing, nothing else. Before this thread started, I never had a strong opinion about it, but having read a lot more now, I'm forming a strong opinion that its difficult for an ABX test to distinguish between any two different audio units. Its not impossible, but its very difficult, and I doubt that I could do it.
However, blind tests, no problem. I've done it before with stock and TUC modified units and passed the test.
Nick
post #1424 of 1596
Dave, what is it that you have from TUC?
post #1425 of 1596
Dave
I had zero expectation that any test we could have conducted would have been seen as credible by people holding your view of these mods. It was not conducted to change the minds of that group .. because absolutely nothing would.
The switch is no more an "unknown variable" that could have affected the sound quality anymore than the layer of unknown molecules that settled out of Dennis' overhead lighting onto the RCA phono cable connectors before we plugged them into the backs of the units. What molecules? Well, we just don't know, do we?
If that sounds absurd, then you know how the switch objection sounds to nearly everyone else.
Jeff
post #1426 of 1596
[quote=thezaks;21947206]
What kind of tests are you looking for that would show TUC modded gear actually does what DS claims? For me, I've been able to conduct my own tests, with my preferred method, in my own home. I wouldn't even want a switch to be included in the testing, so, for me, I don't care about testing the switch.
Dave,
I would start with testing both a stock 5508 and a TUC modded 5508 to see how well both handles RFI/EMI issues. Then I would like to see the results of how each compare when in room measurements are done. Of course in room measurements would be taken in the same room as when Jeff did his comparison (with or without the switch). What tests or measurements did you conduct that indicate the TUC modded gear you have lives up to the claims that DS makes?
For those who used the switch, a variable was introduced with an unknown impact, and it now seems that folks would like to have tested the switch, in order to determine the impact it has/had on the tests that were done.
What tests would you suggest be done on the switch to show that it effected or did not effect the comparisons made?
Bill
post #1427 of 1596
i'd start by measuring/analyzing the unmodded unit to see if there is really any issue to be solved in the first place...
the first leap of faith that is being made by those who purchase the mod is that the "problem" even exists...
post #1428 of 1596
Jeff,
Dave and I aren't here because we like David Schulte and we want to support his business nomatter what. We just want the best gear we can get for the money, and we happen to have had a lot of success with with TUC. If we found something better, we'd change our minds.
For me, that WOULD happen if you could distinguish between the 886 & 5508 in an ABX test. As it happens, I'm also working on three other little projects to try get something better.
For the record, I believe the TUC equipment that Dave has owned is:
Pioneer BDP-05
Marantz AV7005
Onkyo SC5508
While I've had:
Onkyo SC885
Denon 3800BD
Pioneer BDP-09
Nuforce BDP-83SE
Oppo 95
Regards, Nick
post #1429 of 1596
Originally Posted by welwynnick View Post
Jeff,
Pioneer BDP-05
Marantz AV7005
Onkyo SC5508
While I've had:
Onkyo SC885
Denon 3800BD
Pioneer BDP-09
Nuforce BDP-83SE
Oppo 95
Regards, Nick
Nick, in your quest for the "best you can get for your money" have you exhausted all the conventional upgrade paths then and TUC is a sort of 'last fling' for that tiny potential improvement?
What I mean is have you already extensively treated your room for example - knowing that the room is by far the most important 'component' in the system and the one that has the most impact on the SQ?
Have you also splashed out on the very best speakers you can afford - again knowing that it is in speakers where the really big differences in SQ can occur? Ditto for subwoofers if you use them?
If so, would you say that $1400 spent on room treatments and better speakers would bring you even better results than the same money spent on a TUC upgrade of an AVR?
Have you used any of the sophisticated, and proven, electronic EQ methods, such as Audyssey XT32 or Audyssey Pro in order to squeeze the last drop from your system and room?
I am not trying to be confrontational at all - just wondering where a TUC-style upgrade fits into your scheme of things. For me, for example, it would be the very last thing I spent my money on. I'd have done everything possible to treat the room, to use the very best speakers, to buy the very best stock units with the best electronic EQ etc, before I even considered an aftermarket upgrade, especially one which comes with no manufacturer-provided evidence that it actually works.
post #1430 of 1596
For me, the point of this thread is that the improvement is undetectable under ABX conditions, and not that it's undetectable.
Anything is "detectable," if one strips away all possible controls and makes the evaluation as leading as possible, of course. One can easily even hear the difference between one box and itself - by twirling the volume control a bit! That's every bit as valid a "test" as any other sighted listening session.
Anyone is entitled to believe that an ABX test must be used to determine detectability, but if you go down that road, you may have to accept that all hifi equipment does sound the same.
First of all, you're just wrong on fact. There have been plenty of ABX tests that have shown two given DUT's to be different. But that doesn't matter, really. Just one would be sufficient to make you simply wrong on fact.
Second, what if most audio kit does in fact "sound the same?"
That's what the most sensitive controlled subjective same/different listening evaluations tell us, after all!
To deny that possibility is to show a troubling willingness to look at simple reality and be willfully blind to it.
Fir the record, I didn't "call the switch into question." I said it was "controversial", which, obviously it is.
There's a difference between actual controversy and manufactured controversy. To claim otherwise is to say we live in a pomo dystopia where any fact contrary to the interests of any actor instantly becomes "controversial" if that actor whines loudly enough about it.
Here, the simple fact is that a few people with skin in the game are unhappy with observed, and out of some self interest they're trying desperately trying to spin until they can convince others that 2+2 = banana. There is no good reason to give any deference whatsoever to such an obviously manufactured "controversy."
post #1431 of 1596
Jeff,
Pioneer BDP-05
Marantz AV7005
Onkyo SC5508
While I've had:
Onkyo SC885
Denon 3800BD
Pioneer BDP-09
Nuforce BDP-83SE
Oppo 95
Regards, Nick
I'm curious about something (and maybe that is why I continue to follow this thread). This is an impressive list of equipment. When you use the various BD players, do you use the digital outputs or the analog outputs for audio to the AVR (or separates)?
post #1432 of 1596
But much faster and that, in itself, is a huge advantage.
post #1433 of 1596
Jeff,
Pioneer BDP-05
Marantz AV7005
Onkyo SC5508
While I've had:
Onkyo SC885
Denon 3800BD
Pioneer BDP-09
Nuforce BDP-83SE
Oppo 95
Regards, Nick
I would be curious as to if this large list of modded gear had been listened to in its stock form or sent directly to TUC for modification.
Bill
post #1434 of 1596
Robert,
Nick
First you say:
Then you say:
Since A and B are being compared to X (an unknown), an ABX test IS a blind test, either single blind or double blind. This means that you're essentially saying:
"There's nothing wrong with an SBT or DBT" AND "The problem I have is with a SBT or a DBT, nothing else"
You're making contradictory statements that cannot be simultaneously true. You're either opposed to blind testing or you aren't. You can't claim to have no problem with it AND have a problem with it.
Dave
So, just to be completely clear on this, you would have no problems with the validity of a DBT using manual cable swapping? None at all?
post #1435 of 1596
First you say:
Then you say:
AND
Why would he have a "problem" with those tests? Since there has not been an ABX or DBT done in regard to the TUC components, it's really a moot point. And with no statical sampling of any credible kind to reference, where does that leave all those who are critical of TUC?
post #1436 of 1596
I guess it leaves everyone in the same place as TUC who states they've done DBT's.
post #1437 of 1596
I currently have an Onkyo 5508 and a Pioneer BDP-05FD Blu Ray Player. I previously had a Marantz AV8003.
Dave
post #1438 of 1596
Your opinion, but an unknown until tested with cable swapping vs switch with the TUC upgraded 5508.
Dave
post #1439 of 1596
Jeff
Unfortunate and fairly biased.
Dave
post #1440 of 1596
The same place as always...with no critical analysis of the pre or post performance specifications of the "upgraded" components and no reason to believe that some silver tape, copper wires with shielding, and some capacitors do anything at all to improve the performance of the component and that it's a waste of money if one wants to improve sound quality of the system.
