[quote=Bill Mac;21948534]
Hi Bill,
Great questions and suggestions for testing. On the subjective side, which is what I prefer, I had benchmark(s) for comparison. The benchmarks were not a stock units - they were more expensive units of another brand. After all, I don't want to just improve on the stock unit, I want the upgraded unit to be better than units costing more $$$. I compared stock to the benchmark and then compared upgraded to the benchmark. This testing was done subjectively, and fully satisfies my criteria.
With regards to objective testing, I think your suggestions are good ones. For me, unless I'm involved in a blind test of some sort, I don't fully trust the data from other blind tests. There's still a human factor involved, and other folks' preferences may differ from mine. I would also not want a switch dropped in - an unknown variable.
Dave
Originally Posted by thezaks
Dave,
I would start with testing both a stock 5508 and a TUC modded 5508 to see how well both handles RFI/EMI issues. Then I would like to see the results of how each compare when in room measurements are done. Of course in room measurements would be taken in the same room as when Jeff did his comparison (with or without the switch). What tests or measurements did you conduct that indicate the TUC modded gear you have lives up to the claims that DS makes?
What tests would you suggest be done on the switch to show that it effected or did not effect the comparisons made?
Bill
Dave,
Bill
Hi Bill,
Dave
