Originally Posted by Johnla
Well the salesman is wrong, or he just flat out lied to you. Both the 80.2 and the 5508 have the option of Audyssey Pro calibration, either by having Audyssey Pro dealer do the Pro calibration or by buying your own Audyssey Pro installers kit.
Make up your mind, they will sound the same.
But if you bet on the 80.2 being better, it would be a bet that you would also lose.
The Anthems ARC room correction has more options and adjust ability than the standard built in version Audyssey that is offered in the Integra/Onkyo, however if you compare it to the Audyssey Pro version, then if you put them up against each other they are probably more equal than you would think.
And of course he is also going to want to try and sell a person whatever he can to maximize his profits, and likely will start out with trying to steer people towards his more premium products.
My points exactly, with both this sales person and TUC; if they lie about things like this, what else are they lying about?
Jeff
