AVS › AVS Forum › Audio › Receivers, Amps, and Processors › How do I verify - or debunk - the claims of The Upgrade Company?
How do I verify - or debunk - the claims of The Upgrade Company? - Page 15
post #421 of 1596
Originally Posted by oddiodog View Post
Doing it both ways is completely fair. I doubt there a rational reasonable reason not to try it both ways.
Agreed.
PS. The biting sarcasm before the experiment does show a sense of humor. But it also displays a lack of discovery abilities. Scientists wonder about and explore the unknown and untested and concoct experiments to discover new things.
Understood. I have lots of experience as a scientific experimenter (outside of audio) and all I want to see is that the testing is blind.
So, while I hope I can attend, I can supply matched pairs of whatever connections are needed in addition to the switch. Of course, it is necessary for all parties to approve these ancillaries before the test so that they do not engage in post hoc arguments about them.
post #422 of 1596
This is great news that Rich, Jeff and possibly others will doing a comparison of a TUC modded 5508 to a stock 5508. I hope this happens as it will be very interesting for many members to have a controlled comparison done. I certainly will be very interested in the outcome as it will put to rest if mods done by TUC are a worthwhile investment. Will there be any peeking under the hood of the TUC modded 5508?
Bill
post #423 of 1596
Pepar and Rich: I am still very much interested in doing this comparison. I am fine with A/B or A/B/X, but I think it would be best to do both, just to eliminate anybody saying that the test was not valid because it wasn't a blind A/B/X test.
post #424 of 1596
PS. The biting sarcasm before the experiment does show a sense of humor. But it also displays a lack of discovery abilities. Scientists wonder about and explore the unknown and untested and concoct experiments to discover new things. They only USE people who are good at researching and retaining knowledge because they think more like a computer than creator. They are good at swirling information around that has already been discovered by someone else. Since they are good at researching existing info and retaining it, they are also good at swirling around verbal sarcasm to help protect their own deficiencies.
Science is about discovery.
Imagine a cell's understanding of existence. It's universe is swimming around an unfathomably large cavern of goup going about it's tasks. That's it's universe. It simply doesn't have the capacity to understand that it's inside a body that lives a life in a greater universe. It has constraints of understanding.
We, as humans, are much smaller and more naive when compared to our (assumed infinite) universe. We are minute and a very new species compared to the age and size of the universe. And I imagine our knowledge is even more limited in our abilities and dimensional constraints. Probably even if we could use more than 5-10% of our brains. We are still limited by an understanding of constraints. We don't really have the ability to understand not having a beginning and an end. Or not existing as a structure.
Try not to display our naiveness too often until after the test has been done. If you haven't done it, you don't know. You simply assume from what you have read. The sarcasm can lead to the test not happening. Unless avoiding the test for some reason, is the goal.
the longest "PS" i've ever seen ...
post #425 of 1596
You mean, lessen the possibility that they engage in post hoc arguments. There is certainly a possibility that one person can distinguish no difference and the other does. In a common cable test referred to hear on AVS, this was left there without the option of a second listen and a barrage of audio tests in unfamiliar surroundings, and reported no better than a 50/50 outcome and therefore concluded as cables making no difference. That test is flawed in more than one way.
With this much smaller environment, and less time constraint, there should be time to listen intently to a SHORT movie scene over and over again on the same system with describable sounds in effect familiarizing themselves with the subtle nuances of the audio system and the test material. Engraining the sample as much as possible into their memories. Then do the ABX test. And do it again. Give the listeners the option to hear the sample again if requested. There will be new variables in the room with people there and some will not be familiar with the system. Don't change the people in the room, or their positions. Keep the mood steady for the tests.
There still may be a mix of people who can hear a difference and others that can't. But for the one(s) who can determine the correct processor repeatedly, then that would suggests there is a difference, but not necessarily everyone has the capabilities of hearing it. Re: varying human abilities. But still a difference. In that case.
Do it like that. Do it repeatedly. Do it with and without the switcher and compare results. Then you can be fair about it, and put to bed whether there is a discernible difference. If there is a difference, we can argue about how much of a difference it made later. Maybe if they determine they hear a difference then they can try listening to new material only once and see if they can detect the processors.
If it was me, Nature, I'd want to use standard cables for the test. If in fact your upgraded cables are reducing static noise and lowering some of the noise floor, then I would think it would lessen the difference the upgraded processor would noticeably make since from what I understand, it's supposed to do the same thing. Diminishing returns. Just a thought. Maybe my logic is flawed here.
post #426 of 1596
Bill
I plan on bringing my sawzall!
post #427 of 1596
Now that's the kind of sarcasm I do like. Indisputable. Told you terseness is not my strength.
post #428 of 1596
lol. You're on a roll.
Don't worry Rich, your modded processor might not make it out alive but I'm pretty sure this thread is evidence that in your lawsuit you could recover not only the value, but also a hefty bonus for mental abuse.
post #429 of 1596
Perhaps Monica Lewisky can attend. Her Secret Service name was The Jaws of Life.
post #430 of 1596
post #431 of 1596
Wow! I thought that TUC just put stickers on the covers not steel banding.
Bill
post #432 of 1596
That might, or might not, increase our pool.
post #433 of 1596
She could help pole poll the listeners.
post #434 of 1596
Don't invite Monica. Her attendance will no doubt result in a hum
Cheers,
SB
post #435 of 1596
Kal,
Given your eminent credibility, would you be willing to do a scientific A/B if I were to purchase a TUC modded 80.3 and sent it to you? You'd, of course, have to buy a stock 80.3, but I bet you could just A/B it with your 80.2 as well. What do you think? Specifically, I would like to either confirm or refute that their mods are beneficial and to see the level of improvement. I have no bias either way, but have an interest in knowing if the mods are truly beneficial.
What do you think Kal?
-Ken
post #436 of 1596
P.S. for the record, I have no issue if you or anyone at Stereophile want to remove TUC stickers and void their warranty. I just want an honest assessment. I am aware that you'd have to keep the unit for some time to allow it to burn-in (if necessary) and to fit this into your busy schedule. Thanks.
post #437 of 1596
Part of the audiophile ethic, as I see it, involves tweaking. So it would be great to see what gains, and at what cost, can be heard in this tech era where mods seem more difficult and ever more expensive.
post #438 of 1596
Agreed. Interestingly enough, the comment in their FAQs that mid-fi equipment tests the same as hi-fi seems to be self-serving. According to them, even though mid and hi fi test the same, "real world" listening results are quite different. I can think of at least one person (Michael Fremer) that might disagree that mid and hi fi test the same, but that's conjecture and supposition on my part. I just want someone credible to put an end to all of the theorizing and postulating on the Integra 80.3 mod in particular.
Kal, I/we really do need your help.
post #439 of 1596
Hummm dead thread since middle of November.... wonder what ever happened in the test ?
post #440 of 1596
Originally Posted by GadgetGuruKen View Post
Kal,
It is something that interests me greatly but not something I can fit into my schedule. Perhaps when I retire from my day job, I will have time to pursue such things.
post #441 of 1596
Dunno but I volunteered to assist if it went through.
post #442 of 1596
Kal,
Any chance you could undertake this as a personal project and just report your subjective opinion on this forum?
Have you ever heard any other modded equipment and if so, what were your thoughts?
post #443 of 1596
The owner of the modded 885 sent it back to TUC for the "latest" mods. It was damaged irreparably on the way back, so the owner purchased a modded 5508. That took quite a while. During that time I had sold my 885 and bought a 5508. At that point, I guess we could have pushed forward on it, but during all *that* time, some of us lost interest.
Part of that losing interest was that, in discussions with the mod owner during all this, it became tortuous to agree on a procedure. The non-believers (note I said "NON" and not "DIS") wanted double-blind A/B/X. Kal volunteered his switch, specifically made for this kind of thing. The believer could not be separated from his idea that the switch would cause the modded unit's sound quality to be negatively affected. And he would not accept that the passive switch would, at worst, equally affect both units under test. He was told all this by the owner of The Upgrade Company.
"In science, contrary evidence causes one to question the theory. In religion, contrary evidence causes one to question the evidence." (Toole)
THESE MODS ARE FAITH-BASED.
Jeff
post #444 of 1596
Color me unsurprised.
post #445 of 1596
Jeff
Jeff,
Thats too bad that you were not able to pull off the comparison. The TUC modded owner (Rich?) seemed to be a decent guy that was all for doing the comparison. The issue of the passive switch degrading the SQ of the TUC modded unit is total BS. It once again shows that Dave Schulte at TUC is just a scam artist IMO. If there was actual gains in SQ with TUC modded gear one would think he would want to show it through the comparison. But of course he talked the owner of the TUC modded gear out of it. No disrespect to any TUC customer but when does one see how much BS TUC's mods really are.
Bill
post #446 of 1596
By this time it should be obvious to any rational human being that the Emperor (Schulte) has no clothes.
Cheers,
SB
post #447 of 1596
Slappy reports that he definitely hears a difference and thinks it's worth it.
Jeff
post #448 of 1596
Jeff
Well then that settles it.
Bill
post #449 of 1596
Apparently, Mr. S continues to be his usual, tactful self.
http://www.meridianunplugged.com/ubb...=148622&page=3
post #450 of 1596
Notice he had a post count of 8 on that forum. I'd bet that a lot of his time is spent traveling around the world (virtually) to different forums and squelching the threads that threaten. He got the thread closed, so on to the next one. Hey, maybe it'll be this one.
