Originally Posted by Ronomy
The other issue here is you may be using too much duty cycle and you see ghosting because the panels don't refresh quick enough. The amount of depth in the image changes and when the separation between eyes is greater you can see more ghosting. I have to be down around 50-60% duty cycle to eliminate ghosting in these great depth of image scenes. Maybe you feel it shouldn't be that dim. Sorry to say it does need to be dim! Your duty cycle is too high and there is some ghosting. Get a high gain screen and lower the duty cycle.
This would explain why some people have problems and other don't. Also I agree with the power requirements. You must have a 5V USB power supply that can supply 1 Amp or 1000ma of current or else the emitter might flip polarity and do god knows what. I also found that lower current power supplies will work for a while and then things start to screw up.
power supplies are not a problem, i design them for a living. For screens I don't need any more I have 3 silver torus gains of 6, a home made silver PVC, grey wolf gain of 1.8 amongst others. The bottom line is you set the acer and watch minmum hastles. Try to use 60 hz projector for 3D a royal pain.
