Originally Posted by Ronomy
OK! Decided to just do it and build the emitter driver for my RS1u. Ordered some of the parts tonight. Will use a JK flip flop with dual polarity outputs. Install a switch to change polarity. I'll tap off Vsync which is already passed through a gate. Probably just solder on to that output (actually a test point) and signal ground with a small coax to bring it out of the projector. The RF emitter will plug into my little circuit via a bulk head mounted female 3 pin mini din. I need to hit the local electronics store and get a small project box and project circuit card so I can build it. I have some extra 5 volt power supplies kicking around in work I can grab. Hopefully be up and running soon enough.
Ron
Ron
How did you get schematics for your PJ? So far I don't need to crack open any of my units but I think I would have a hard time to get the schematics if I needed any. Good luck with your project.
LOL
It's well cared for and has a fresh bulb.
