Is there any sonic difference between the two mechanisms for getting FLAC data to a DAC? Is one the interface of the future?
USB DACs have evolved over time so that the current State of the art is an asynchronous implementation that cuts down on Jitter.
Audio unpacking of FLAC is performed on the PC and your media player controls this process. This is not a processor intensive process and the USB interface is fast enough for all of the high res audio data. The limitations of a USB interface is that USB cabling is limited to 15 feet and asynch DACS are pricey right now. Your media player (PC running JRiver) must be close by.. (Noisy fan in some cases).
A DLNA DAC such as the Oppo 95, exists on your home network, and takes the data over an ethernet type cable or wireless and delivers it to a buffer. The data streams to the player. The Flac data is unpacked by the chip in the DLNA client player and then passed to the DAC. The critical timing information must be controlled by the clock on the DAC... Players like the OPPO can take data from shiny discs, and Flac or wav data from usb or E sata drives. The latest versions will handle high resolution files.
I think your media controller (either the attached PC or a hand held device running the atttached PC via gizmo or a NAS Drive with DLNA server software) will spool out the content you want.
Are the two interfaces equal and sound quality will depend on other factors,
Are there jitter measurements of both that are meaningful?
Is the DLNA interface the future of high res audio?
. FLAC is not a supported format for DLNA. Indeed, the only mandatory format (unless something has changed recently) is LPCM (uncompressed). The "server" software running on the PC will decode the FLAC stream then and send it out as uncompressed to your player.
