AVS › AVS Forum › Audio › Speakers › substitute for a CS1 center-help
post #1 of 8
I posted a thread about CS1 size few days back but now im looking for a substitute for a polk audio CS1 center speaker to use with my monitor 30s.Its too deep to hang on wall (9-3/4 inches Deep) but i still want voice matched to my monitor 30s. Can't use any supports/mounts also.
Whats the best alternative to this, anything not more then 6 inches deep ??Is getting different center would be bad? Otherwise i have to go with a complete jamo A340PDD.5 system for my medium size room.
post #2 of 8
post #3 of 8
Originally Posted by ministerjee View Post
would this Polk audio CSR match??
http://www.amazon.com/Polk-Audio-CSR.../ref=de_a_smtd
Nope not at all.... Might want to try the cs10 or just build a deeper shelf
post #4 of 8
hmmm..well CS10 is same as CS1 in measurements.
may be i should get different brand fronts with matching center...any suggestions? i really liked polk thou.
post #5 of 8
Well the price of the A340PDD.5 just went down $50 so maybe that would be a good move for you?
http://www.vanns.com/shop/servlet/it..._c=site_search
I don't think Polk makes smaller center channels to match your Monitor 30's.
post #6 of 8
KEF T series
Pinnacle QP
Def Tech Mythos...
post #7 of 8
yes, i know about this, i might get it ,however 5 inch woofer (polk) vs 4 inch in jamo satellites most likely will produce little low sound.also i dont know why its 6 ohms for 4 of the speakers in specs.i know sub is good, but i want good sound from center and fronts as well.
post #8 of 8
that is over my budget,i want something under $300 for LCR.
Originally Posted by schan1269 View Post
KEF T series
Pinnacle QP
Def Tech Mythos...
  Back to Forum: Speakers
