Originally Posted by
scoyne88
What sizes did you order? I am going to see if they will send me a sample as well
For the cpu, I got the 2040A127, which according to their numbering system is 2mm thick, 40mm wide and 127 mm long. They also gave me a 1220A100, which I used on the SB chip. If you can, I would get something a little longer than 127mm, since you want to maximize the length of the condensing area, and for my motherboard and its cpu placement, I don't have quite as much condensing area as I would like. I think with a little longer coolpipe, and more condensing area, I could get the temps down even more.
The company did say that they won't sell small quantities to the public, only OEMs. And they will only sell lots of 200 to 500 pieces. As far as I can tell, there are no resellers here in the US, or anywhere else for that matter. These coolpipes are pretty amazing and unique, so I'm hoping that someone here will see this, bring in some stock, and sell me some for further builds. There's nothing like a small, completely silent and cool htpc. Good luck.
