AVS › AVS Forum › Audio › DIY Speakers and Subs › New Funkywaves High Efficiency Monitors?
New Funkywaves High Efficiency Monitors? - Page 3
post #61 of 98
I have a custom HT room to do with as a please .
Nice.
I have no idea what ASW is...
ASW
....but spaciousness will be determined when I get them running (probably late summer).
True. But no game plan? Are these specifically for HT, like the room?
Yes, some post that its 100% no-no. Declaring the designs flawed. I would say thats a huge generalization without knowing the details or knowing how they sound in the end.
So it basically comes down to personal preference...
....subjectivism?
cheers,
AJ
post #62 of 98
Originally Posted by AJinFLA View Post
Nice.
ASW
Game plan right now is to get down below 500Hz with a single point source. That will be the BMS 4590 + IWATA300 horn. Bigger game plan is always buy and build until I stop learning At my current price point though Im already at the Danley SM69 level.
Thanks for the google link.
....subjectivism?
cheers,
AJ
Not really, I said we do not know the detials of the XO. The XO can minimize the CTC enough that it does not matter. The subjective part is to choose if you care about it even if its not completely minimize. You know the the choose your compromise thing.
No one is trying to choose a larger CTC but if we can improve other SQ properties of a design enough then CTC does not matter as much. If Funkywaves worried about the CTC they could pick a different planar waveguide tweeter but at what cost. Maybe that is the best sound planar waveguide tweeter period?? Is CTC so important that someone would pick an inferior driver to fix the problem?
post #63 of 98
On the other hand. I use active XOs so for me CTC is actually a whole lot about nothing
Where in the signal chain the crossover resides isn't relevant to a fundamentally acoustic issue.
From my experience, the biggest thing CTC affects, assuming a well-designed speaker, is minimum listening distance. Big drivers and separate waveguides need some space to properly integrate. Otherwise they sound like separate pieces.
That goes for waveguide-loaded speakers as well as conventional speakers. Listen to a big Dunlavy or Avalon at 3m. Not pretty.
That's another reason coaxes are so appealing.
post #64 of 98
Penn, what does active or passive have to do with ctc issues? The only xo variable that affects that issue is slope: with a lower slope you have more lobing above the xo point; with a higher slope you have more lobing below the xo point.
post #65 of 98
Aaaah, but there is enough information to discern that the design by principle and what we know of lobing and nulls that it is 'flawed'. But now the discussion has shifted to ' acceptable compromise' instead......and that's fine with me. We all make compromises every day. That's why we DIY, to work with the compromises WE choose and not the manufacturer. For the price of a pair of the Funky Waves at 95db efficiency regardless of two high efficiency midwoofers...................i'd DIY my way as far from these as possible thank you. That's my compromise. I'd appreciate it being accepted as it's mine.
post #66 of 98
not exactly true. The steeper the slope the sharper the null making it pretty much a non-audiable measurement discussion.
300dB brick wall filters would sound nice right about now
post #67 of 98
No one really cares what you "might" DIY, no one cares what I "might" DIY either. No one is following your builds period (or mine) I do know that there are many, many fans of Geddes designs and they have followed so much for your flawed DIYers do not choose compromises. We always do!! Some think cheap dayton drivers are actually quality HT drivers, that is what i consider a real compromise
Funkywaves makes great looking speakers, post measurements on their website to back them up. You have zero knowledge about the tweeter used, zero knowledge about the XO but you post definitive opinion on the topic. Please feel free to post real information. I think I will reserve any judgment until real data exists.
Lets see follow what Mayhem has done or follow designs from the likes of Duke, Geddes and even Nathan @ funkywaves. Hmmm...that is a hard one
I find it really funny on what you would DIY 'far from'....mock a company and a person from the DIY world is just bad form considering how bad you are at finishing anything. Actually your biggest compromise is to never shipping back 'borrowed' drivers, any new excuses this year on why you still have them. btw, you can keep them they are low cost crap drivers that I have moved way beyond!
Heck I would love to see an actually finish project maybe finish that big one from 2 years ago, where you had 50 different silly polls,what was the best HT design? hmmm.
post #68 of 98
Alcohol can be a bit of a truth serum. Been drinkin' today Penn?
post #69 of 98
Nope, Worked 12 hours today. Just put the kids to bed and I hate when someone trashes a product that is not even out. Mayhem talks about DIY and trashes a speaker that is not even out yet. he posted he has "enough information"... then I say lets see it. This will be yet another unfinished project from Mayhem.
He talks like he is a great DIYer that all should follow but he must have forget I sent > $100 worth of drivers for a project a long time ago (FREE to him!!!). After 2+ years, nothing completed . Even many PMs I get nothing still never gave a reason for sending them back. Still instead of an answer he chooses to debate and unknown speaker
Yeah, I think someone should worry about their projects (like really old ones with someone's drivers) more then speakers not even built or measured.
post #70 of 98
Penn,
Are you sure the null would become virtually non-audible because of a very steep slope? I can see how increasing listening distance can help create a unified waveform, but I'm not sure that a steep x-over would be sufficient to make the null non-audible. Are you including other variables to assist in its reductions (e.g. distance), or are you suggesting that x-over slope is sufficient to move it beyond the threshold of experience?
Raul
post #71 of 98
Steep slopes remove the high frequency driver - horn, ribbon or otherwise - from contributing below the xo point, which leaves you with raw ctc spacing of mids or woofers as the case may be. You can't use spacing of mid to tweeter as a way to 'cheat' a further separation. If the mid drivers are close enough for the xo then brick wall I agree is fine, but rarely do I find designs that meet that criterion.
You would think that a steeper slope would ultimately limit the bandwidth over which this lobing occurs, and you would be correct as it usually does. But in my experience, if the design has ctc lobing issues, a really steep slope only highlights the problem as there is an abrupt change in vertical response at the xo frequency. Whether things are ok on axis or not is about as important as is the case for the much more journalized horizontal response. Meaning, if you have abrupt shifts in vertical polar pattern the room illumination and power response are affected and the sound can be quite unnatural.
Sometimes the best way to deal with a problem is to ease in and out of the problem and hope psychoacoustic masking helps to prevent calling undue attention to it.
post #72 of 98
...a really steep slope only highlights the problem as there is an abrupt change in vertical response at the xo frequency.
But not if the woofer and WG are the same height, right?
post #73 of 98
I'm not sure I really understand the question noah. Same height as in a horizontal center channel type mounting? If so, just swap horizontal and vertical in my above posts and we're still talking about the same issues. Same height as in same physical vertical dimension of cone or horn throat? If so, recall that radiation pattern isn't defined by just the physical size, especially if we are comparing a woofer and a horn. Even in a two way MT design (where the tweeter is a horn in this case), it is difficult to match the polar response of horn and woofer, though some designs like Geddes manage to do a good job around the xo point.
But my posts were about the speaker topic of this thread specifically, though I guess I should have said that explicitly. This is an MTM design. So my point was that a steep crossover slope removes the horn contribution completely below xo point, which leaves a physically big hole and instant lobing occurs. You go from the radiation pattern of the wide flare horn, which is smooth wrt frequency, abruptly to the radiation pattern of the widely spaced woofers, which will be pretty horrendous to be honest and all over the place wrt frequency. If you're going to design a speaker like the one in the original post, I'd at least avoid really steep slopes so that whatever is happening as you transition from horn polar response to widely spaced woofers polar response is at least done gradually.
FWIW, I haven't heard or listened to these speakers either myself, let alone done any measurements of them. But I do tend to agree with mayhem that some generalizations can be made from appearance alone. I'd be very surprised if the vertical pattern was anything better than "bizarre" to be polite. I draw then same conclusions about the MTM designs you sometimes see using a long ribbon for the T with a mid/woofer on either end. I've seen marketspeak about how this is done intentionally to "control vertical dispersion" and "limit floor ceiling bounce" etc., which really means "our vertical response is atrocious, and you need to sit exactly at tweeter height because anywhere else is a complete crapshoot"!
post #74 of 98
Assuming you mean the woofer is next the WG in a horizontal config, then the null would be in the horizontal.
Penn, Bigus is right, extreme slopes will widen the lobe between the CTC induced nulls, but that has its own issues as well (and there aren't many options for even executing 300db slopes). Beyond that, if the null is literally sitting within a few degrees of the forward axis, you will have "fatal flaws" no matter how steep the crossover.
This is how I see it. You have three possibilities with regards to CTC, either it is non-existent (Coax or single fullrange driver), a workable compromise, or a "fatal flaw". The workable compromise is a function of the desired width of the front lobe. This is where situation and opinion play a part. Each situation requires a different minimal vertical coverage (some are fine with a 5deg window, others want 40deg). Different designers also have different opinions of how smooth their vertical polar map needs to be. Some designers don't give a damn about directivity at all.
Like I said earlier, if the null is present directly on axis, the designer screwed up. Fatal flaw, plain and simple. IMO, anything short of that, without knowing the design objectives, it is always some sort of compromise.
So in sum, Mayhem overstepped somewhat by saying the CTC was too high for the Xover. We don't know the intended frontal lobe height and I'd say it won't be so narrow as to call it "fatally flawed". It likely isn't a compromise Mayhem agrees with but that doesn't mean it is a flaw for everyone or even an excessive compromise for everyone.
post #75 of 98
Interesting, I will have to go through some discussions about this again to figure out what was missed. If both you and coctostan believe it then I have to figure out what piece of information is missing from this discussion.
post #76 of 98
Thanks, Give me 2 weeks to wrap my head around that one
post #77 of 98
Yes.
Ah, gotcha.
post #78 of 98
For the record......it wasn't my intention to bash Nate or Funky Waves......or to incite Penn. I just felt like sharing my opinion. Sorry for the misunderstanding.
post #79 of 98
penn,
I wonder if your thought train might possibly stem from an MT configuration, not an MTM?
In an MT, it is true that brick wall slopes effectively remove the overlap region between M and T, thus no lobing occurs (or more correctly as you pointed out, it is over such a narrow frequency range that we may well ignore it). See above however for my thoughts on abrupt shifts in polar pattern from M to T.
However, again the speaker of the thread topic is an MTM. In this case, what I was describing is the lobing not between M and T but rather between M and M. Brick wall or not, you will still have that lobing. A steep slope allows more lobing below xo, a shallow slope allows more above.
post #80 of 98
Does that mean you're going to reimburse penn for his drivers then, or at least send them back ? As it sits - just the fact those events have taken place makes it pretty clear your opinion pretty much amounts to swat and earn you very little merit - IMHO !!!
post #81 of 98
Could be wrong, but it sounds like from Penn's post above that he sent them back 2 years later?
In any event, my interest in the FW speakers was more from the standpoint that they actually "look" nice which is important in my family room setup. Most of the high efficienty designs I see (e.g., 3pi, etc.) simply look like large theater boxes/speakers and was looking for something smaller/sleeker (understanding that with smaller comes a compromise). When/if I build a dedicated HT, I won't care, but until then ...
post #82 of 98
penn,
Yes, that was my error in generalizing how a steeper slope minimizes the null. I have not done enough research on what happens in an MTM design but I still hold out conclusions even now until Nathan posts measurements.
Nathan is not incompetent as some posts might suggest.
post #83 of 98
Nope, never seen them again. Im fine with experimentation and life taking up time from DIY but putting $$$/resources out there in the hopes of seeing results only to see zero results,zero discussions while someone has time to argue over possible flaws in other designs does not sit right with me. If he has the time to post and debate with me here, he has the time to PM me and say "Hey, I just never had time to get the waveguide design working"
...Im cool with project failure since I have many of my own
Anyways, sorry to you and your thread just asking about these speakers. The look damn nice to me and I have always wanted to try that tweeter!!!
Looks are very important!!
post #84 of 98
Just noticed this from Creative Sound Solutions: Copied from their site:
HEMTM
This high efficiency kit will include as a minimum a front baffle cut for 2 Faital Pro 8 woofers,
the new CSS Planar 1, a crossover and appropriate hardware. A full cabinet flat pack is also
planned and options include a powered sub version with the SDX10 and a plate amp. A center
channel is also planned.
So there will be a kit version!
post #85 of 98
Interesting. Though the question with CSS is always timing, that SDX15 MKII was announced ages ago as well ... nowhere to be seen.
post #86 of 98
Here are some measurements; the first graph is vertical dispersion 0, 5, 10, and 15 degrees, 1/12th oct smoothing. Second is Horizontal 0, 15 30 and 60 degrees, 1/12th oct smoothing. Third is on axis no smoothing applied. All done at 2m, at 1m lobing starts to appear but even then not 10+ degrees off the vertical axis.
Our measurements are done ground plane with the tweeter at recommended height, 28" in this case, So they include ground reflections, we choose to do it this way so it includes the ground refection in the results so we can design it to compensate for this as the speakers are always used with at least a floor under them. No one listens in free space so why make a speaker perfect in free space only to know there will always be a floor reflection in real use. It makes for not quite as nice looking graphs but it is more real world in terms of how they will perform.
post #87 of 98
Looks pretty smooth to me except for the dip around 900 Hz and 14K but overall not bad at all. What do you think the flat pack will cost Nathan?
post #88 of 98
I am quite happy with the design, those dips only appear and grow off the vertical axis and even then are not bad at all. The horizontal dispersion is excellent. But measurments only tell you so much, what really matters is that they sound amazing, and have the ability to really fill a large space.
Not sure on the flat pack.
post #89 of 98
What about the fact that even with the same tweeter height, different listening distances result in a different freq for the floor bounce notch?
post #90 of 98
The goal is to reduce its affects overall, at any distance.
Please note everyone; the Graphs are not at 1watt, so the db scale does not reflect sensitivity.
