Originally Posted by berniez
As prices for cable get out of control, at some point there will need to be a lot more tiers set up. When I was using an 8 ft c-band dish, I could do just that. Buy only what I wanted. That system is now long gone as programming can't be bought for c-band any more. The cable companies probably have the ability to set up ala carte. The problem with channels like ESPN is they are tied with Disney and others. If you want Disney you need to get ESPN also as most supplier companies package their channels together and force the cable company to put them on a basic tier. The cable companies only out is to not buy those packages from the supplier. I am hoping in the future there are a lot of tiers set up so I can buy just the bundle I want. When cable was fairly cheap, it did not matter. Now it is more than my water, electric and gas bill combined. I don't know what choice you have other than to cut the cable and use your outdoor antenna and some online stuff. The small dish companies are no better. The government really needs to step in and force all the providers to make ala carte available. I personally only watch about 10 channels or which 5 are cable only. For that i am forced to buy 150 channels. Pretty crazy.
Bernie
Bernie
Ala Carte is an ideal, but at this point I'd be happy with the feds banishing the practice of program tying. Companies buy up and monopolize channels they force MSO's into "take it or leave it" negotiations. Honestly, the MSO holds the power. If Dish, DirecTV and the Cable Companies formed a partnership where they all simultaneously told the content providers to go pound sand then they could dictate better rates. The content providers NEED cable carriage to exist.
At the very keast, MSO's should be able to dump all sports programming into a "Sports Tier". This would immediatly lower people's bills by $15-20 a month. Just ESPN and MSG make up about $9 of your bill now.
I will be isolating it down to only 2 splits because I can do a home run from his garage as it goes thought both the attic and basement (through concrete). I don't know what the builders were thinking!
