Ok, here is my situation.
To get decent audio from my computer, I'm using the hdmi out from my video card, and routing that hdmi out to my receiver. (Marantz SR7001). This way, the audio goes to my receiver, and I'm able to get 5.1 or 7.1 or whatever.
However, here is the problem. To get the video to my monitor (LG IPS226), I have to obviously go from the hdmi output of the receiver, back to the monitor. When I do this, the video card is thinking that the Marantz SR7001 is my display, and it's limiting me to 720p. The only way I can change this is by going into my Nvidia control panel, and basically forcing a 1080p resolution.
So, what's the problem? Well, in the Nvidia control panel, when I force the resolution to 1080p, the only 1080p options are:
1080p at 59 Hz or 1080p at 50 Hz. I want to set it to 1080p at 60 Hz, but there is no option for this. When I instead connect my video card directly to the monitor, I get the correct 1080p at 60Hz, but then I'm obviously not getting any 5.1 or 7.1 audio, because the hdmi output isn't going directly into the receiver.
My video card is a Gigabyte GTX 560 Ti SOC by the way. I'm using the mini-hdmi output. (which is really pissing me off, but that's another story).
Anyways, I just have a feeling that this weird 59Hz thing, instead of the 60Hz thing is going to be a problem for me. Maybe it won't be a problem, I don't know, but it just seems kinda weird to me. Basically, I'm just trying to somehow get my 5.1 (or 7.1 ) sound, and also get a legit 1920 x 1080p @ 60Hz resolution. I'm new to the whole PC thing, so maybe it's something really simple that I need to do, but I'm just clueless about it. Any suggestions would be greatly appreciated. Thanks.
