AVS › AVS Forum › A/V Control & Automation › Tweaks and Do-It-Yourself › Laptop image to TV over LAN
post #1 of 8
Hello all
I am trying to display my Laptop image on the TV via Wireless/LAN.
Think of the TV as the projector without the cable.
Now If do have a Samsung UE46D6510 TV. There are quiet a few screensharing ads out there and perhaps the TV has to support that too. I am hoping for a trick of hack here.
Thanks for your support
post #2 of 8
are u looking for a static (once-off) capture? continuous video? or something in between like a new picture every 5 sec enuff? And how much are u budgeted for?
post #3 of 8
Hi!
basically the TV should be a second monitor/beamer and I want to stream a picture there. moving, motion not with 5sec interval. Sound is not so important.
best example, surfing the web on the large TV without connecting a cable.
if it works, budget does not matter.
thanks
post #4 of 8
Pay sumbody to write a VNC widget for the Samsung. Anything else requires the addition of external hardware.
post #5 of 8
Perhaps Intel WiDi (Wireless Display) is what you are looking for.
Newer laptops come with the chip built-in, but you can also get the part and replace it yourself. You would then need the Netgear Push2TV Adapter to connect to your TV.
V
post #6 of 8
would wireless hdmi work?
post #7 of 8
there's no wireless hdmi in Samsung UE46D6510.. I had a vnc program written for this purpose
Best Laptops 2010
post #8 of 8
No I meant you could buy a wireless hdmi adapter
http://www.google.com/products/catal...ed=0CE0Q8wIwAQ
like this one
  Back to Forum: Tweaks and Do-It-Yourself
