AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Where to get Pioneer Elite TV Stand
post #1 of 2
I have a 61" Pioneer Elite Plasma and need the table top stnad that goes with it.
I have searched high and low and can find one nowhere.
Anyone have any ideas?
TV is a Pro 1410HD and the stand is a PDK-1014
I have tried the usual ebay, amazon, craigslist etc.
thanks in advance
post #2 of 2
some one on ebay is selling the pedestal feet for that plasma tv this week if you are still interested . the sits on 2 small feet one on each end ,but you can retrofit with a lg visio 57 inch base just add about ten pounds to the base the new ones are light plastic ,so add a metal sheet or thick piece of wood to the bottom it balances out the hevyness of the flat screen itself so it does not topple over good luck
