Well I originally started this as a mid panel brightness settings thread, since I can't find a lot of research into settings that work for this brightness, but some others pointed out we have yet to get an "official" ST30 calibration thread going so let's just do it that way...
I'm like a lot of you in that Cinema looks good but only in low lighting, which really leaves something to be desired in the brightness area.
Problem is an expert calibrator once told me setting the panel to mid destroys the gamma and that it takes SM adjustments to compensate and even then you won't get the PQ of low settings.
So let's start a thread for those of us who wish to tinker with settings and see if we can come up with some good results...
I'll go first. I'm not an expert and you do what I did at your own risk. I followed the D Nice panel prep method found at the Site Which Shall Not Be Named which you can find HERE.
From out of the box straight to panel prep. Ran my TV for 100 hours straight, no normal viewing, on 1080p color slides (file included with this post), with D Nice's settings.
If you follow these settings exactly, the slides should be on a continual loop of 30 seconds per frame. I let that run from Monday to Friday.
Once done, I decided to use D Nice's post panel prep settings as my reference settings that I saved as default.
Currently I am trying settings with panel set to "mid" brightness. Started with these:
Custom
65
80
37
0
20
Warm1
off
off
off
Pro:
Normal
+7
0
+17
+7
0
+2
Black ext. +2
Gamma 2.4
Panel Brightness Mid
off
AGC 0
off
off
off
So how about you guys?
Custom
65
80
37
0
20
Warm1
off
off
off
Pro:
Normal
+7
0
+17
+7
0
+2
Black ext. +2
Gamma 2.4
off
AGC 0
off
off
off
BreakIn_Images.zip 7.6904296875k . file
Although I can't seem to change the thread title...
