AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Panasonic ST30 DIY Calibration and Settings Thread
Panasonic ST30 DIY Calibration and Settings Thread - Page 39
post #1141 of 1409
I got my P60ST30(october 2011 build) in mid March and did not do any of the Dnice(sp?) settings because I could not see leaving it on unattended while at work. I did turn everything way down and used settings from this thread. I have only watched full screen material, mostly without logos and have not played games that much. Anyway, I have a SpyderTV(it might be the Spyder3TV, but I can't remember and am at work) colorimeter that I used with my old samsung lcd and was wondering if it would be worth trying?
post #1142 of 1409
Not sure on the accuracy of those meters, do you have calibration software like HFCR ? Couldnt hurt to measure and see where you are at grayscale wise. If you are willing to put some time in and learn might not be a bad experience for you. You might ask some follow up ?s about your Spyder 3 over on the calibration forum.
post #1143 of 1409
I just have the calibration software that came with the device. It seemed to do pretty well for my lcd when I had it. I might have to look at the calibration forum then.
post #1144 of 1409
Yeah it would depend if that software supports smaller windows patterns which you will need to calibrate a plasma because of ABL.
post #1145 of 1409
I will have to check on the software when I get home to see if it supports plasmas.
post #1146 of 1409
If your meter works with HCFR you should be set it is free. Would just need some calibration patterns if you dont have those already.
post #1147 of 1409
I can confirm it is alot of fun , but once you start you will be obsessed till you get it right or frustrated because you can't. Either way it is a great learning experience about the factors that go into getting a great calibrated picture.
Yes, and the obsession/frustration is the fear. Right now, I am able to sit back, enjoy the tv and the outstanding picture it has. I would love to learn and to try to optimize it, however, I dont want to find the additional flaws in this set while doing so.....I seem to be very sensitive to them......
post #1148 of 1409
Originally Posted by Jimmy View Post
Watch it, gremmy will be selling his VP to you so he can buy the one he really wants.
Well, Gremmy will have to sell his meter along with it, so that I could even take advantage of it.
Gremmy? Package deal?
post #1149 of 1409
I have very little experience with 3D, but I ordered a couple of pairs of Panasonic glasses (third generation from shopblt) to go with my open box 60" ST30 (from HDTVGUYZ) (fingers crossed it arrives in good shape).
I've read that using a different brand of 3D DVD player is not an issue. I have an LG BD670 that I use all the time for streaming .mkv HD across my wired gigabit home network. I could sell the LG and pick up a Panasonic, but it seems pointless. Why would I want a Panasonic DVD player that basically duplicates the capabilities of the TV? Wouldn't it be better to have a different brand of DVD player to have an alternate smart interface? If having a different brand of 3D DVD player compromises picture quality in any way though, then I can easily pick up a Panasonic. My local Bestbuy runs unbelievable open box deals on DVD players. While the LG BD670 was still $199, I picked it up for $70. Right now they have a whole shelf full of open box Panasonic players.
post #1150 of 1409
You shouldnt have any problems at all with another brand of 3d player, I've used a Sony player with no issues for over a year.
post #1151 of 1409
Agreed, if you are happy with your set then I would just leave it as it is.
post #1152 of 1409
Originally Posted by ttnuagmada View Post
Cobra, are you calibrating just the greyscale, or are you doing primary/secondary as well? If you still have your color at 50, this might explain why some stuff looks strange, and some doesn't (*)
Also, the contrast setting isn't going to clip anything on our sets. It's going to do little more than up the light output, though I think i've read that anything much over 78-80 can cause a green push. Your ftl measurments indicate that you're probably using the fullscreen fields, am I right? Use the small APL windows instead (*)
I ended up calibrating with BE at 4+. I didn't realize that I was losing shadow detail in the really dark areas until i started playing with it (*)
Originally Posted by 65Cobra427SC View Post
I'm somewhat short on time at the moment (*) I haven't done the primary/secondary adjustments (*)
(*) Material removed from original posts.
Wow, it's been a week already but I finally had a chance to do another calibration last night... Custom, +4 BE, Mid Panel Brightness, Normal Color Temp, 2.2 Gamma, Auto/Graphics HDMI. Used my i1D3 with newest version of HCFR 3.0.3.0 Beta. I also burned a DVD with the AVS HD 709 patterns and used it for everything instead of the DVE disc.
This time I read about Primaries and Secondaries, Color and Tint... very interesting stuff that completes the puzzle. Now I more understand how a CMS would improve things. Calibrating is like plotting points inside a box (or triangle in this case) without knowing where the box is to begin with, then attempting to build the box afterward.
I'm going to hold off posting all my settings for a couple reasons, but primarily, HCFR is being updated to work better with the i1D3... seems like that meter needs some special attention compared to the others... so I want to try this again with the next revision. But in the meantime...
Contrast: 85
Brightness: 65
Color: 41
Tint: 0
Previously I could decrease Contrast to 80 before ftL would drop by significant amounts... this time the cutoff was 85.
For Brightness, the AVS disc didn't have the same pluge pattern as the DVE disc so I used a screen with a series of vertical flashing bars... adjusted Brightness until I could just see #17 flash.
Color ended up at 41 which was lower than I expected so I want to take another look at this. Color accuracy is more consistent but the overall look of the display is somewhat dull.
Tint did not require any adjustment... the x/y values for cyan, magenta and yellow were all very close to their targets. Although I guess having Color so low and a dull display could be the reason.
I want to use these settings for a day or two just to see what I think, then do another calibration. In the meantime, please feel free to comment... ahhh... as long as they aren't personal
post #1153 of 1409
Cobra:
Just curious are you using a blue filter to adjust Color and tint or are you using patterns of th 709 disc ? If you are using patterns you might try the smaller APL windows, read in some review about Panny plasmas that using the smaller windows helps mitigate ABL issues and you will end up with a higher color setting. For example mine came out to 46 using the APL patterns. Might be worth a shot if you feel your color is washed out.
Those brightness and contrast settings are pretty consistent with what I found if I used Be+4.
post #1154 of 1409
Contrast: 85
Brightness: 65
Color: 41
Tint: 0
Based on your initial readings, you seem to be on the right track.
post #1155 of 1409
Cobra:
No filters... used the patterns on the 709 disc for everything. I did try to use the smaller windows but I felt clumsy the first time around, trying to figure out where everything was on the disc. I'll be running another full calibration soon since I had the same problem the first time I tried to adjust greyscale. Will report back. Thanks.
post #1156 of 1409
I've been waiting. You better learn quickly and take your best shot. I have countermeasure settings written down just in case the crown is threatened. Oh, wait a minute, I gave my word I wouldn't do that didn't I?
post #1157 of 1409
Counseling made me realize that my display just doesn't fit the norm and both my display and I have finally learned to accept that. Tis better to have worn the crown and lost, than never to have worn the crown at all.
Watched commercials for The Killing and Mad Men on AMC last night and both looked better... Mad Men wasn't as red... The Killing was harder to judge since I don't care for the way it's filmed to begin with. However, it's possible the commercials were shown in a lesser quality so I'll see what I think on Sunday.
Can't recall who here has a P60ST30 but I'd be interested in the Service Menu settings just for comparison purposes. If you would rather PM them to me, that's fine. I can also post mine if anyone is interested.
post #1158 of 1409
Cobra, I also watched The Killing, because you mentioned it so much. Yeh, I don't like the quality at all. It's the way many of the shows are being filmed these days. Dark rooms, dim table lamps, dark hallways, almost black and white, no color, on and on. I have also noticed that commercials are using film editing and transitions that will use just about every grab your attention gimmick, that are actually TV flaws. I see line bleed, false contours, pixelation and others I don't know the name of. More than once I've seen these film add ins and thought "what the". It couldn't have been my TV. After all, I am using Jimmy's settings.
post #1159 of 1409
I'll ignore that last remark
I'll probably get flac for this but I'm going to go off topic just once... so let me appologize now... so I can ignore the comments later
I agree about the way film is being used today but I still watch The Killing because I like it, the darkness isn't distracting, and it doesn't try to shove things in my face. It used to be easy to ignore things like that... i.e. the shaky camera syndrome of Blair Witch Project, Cloverfield, etc... because I just didn't watch them.
Unfortunately, this has become the age of in your face advertising. The TV Station logo went to color and now they twist, turn and dance. Distractions have since moved to other corners of the display and now they want to shove things in your face while you're trying to watch a program.
I'm older... going on 60... but I'm not an old fart... 2 Hayabusa's, one turbo charged, and a 65 Cobra replica. Even though I have no interest in Facebook, Twitter, etc. at least they don't haunt me. But the tactics they use on TV irks me to no end. And they will use any trick they can just to get us to "glance" at what's on the screen. I've noticed movies that used to be in a 2 hour time slot, are now in a 2-1/2 hour slot but I would rather have longer commercial breaks than have bling shoved in my face while I'm trying to watch a movie or other show. Problem is they want to do both. I'll be glad when the law which limits volume during commercials goes into effect later this year but I'll probably be dead before they outlaw what I refer to as "Sling Bling".
I'll have time to do another calibration tomorrow since something on my schedule was cancelled.
post #1160 of 1409
My feelings as well. Especially about filling the corners and pop ups across the bottom. Let's face it though, it's not going to stop. My wife and I find ourselves not watching so much TV but yet we have so much invested in it. Comcast alone is as much as some car payments. I was a DTV customer for 13 yrs and it was as costly, for less.
On the age thing, you're just a kid. At least you seem to act like it, good for you. I would say you are at half life though. You probably need to be re-calibrated.
OK, back on subject now. I will say, I continue to get PMs requesting the settings and it is surprising how many report back they really like them. The D-Nice/ Combination DYI (how's that for correctness ) settings seem to be fairly universal, if not for everybody. I think that is a good thing and this has proven to be a good thread. Our job should be done. However, we'll wait for your last word.
post #1161 of 1409
Are these the current settings? /post 845/ (I can't post a url)
I replaced my beloved TH-50PX80U with a TC-P65ST30 and was disappointed as the initial settings I arrived at made everything look like a super hi-def soap opera. Thanks to everyone for this thread and their efforts...so satisfied with my new Panny.
Gave the 50" to my buddy who was still using a 31" Panny SuperFlat CRT and OTA converter.
post #1162 of 1409
Yes, but use normal color temp.
post #1163 of 1409
Hi.
I'm trying to use the slides you can down loan here to run for 100 hours to break-in the set before trying D-Nice's settings. I've used them before a few years ago without issue on a Samsung.
But while I can basically get them to work on the ST30, between each slide it comes up with a blank black screen and says the file could not be read. Then it cycles to the next slide just fine, and repeats this between each slide. I checked and it does show each slide so none of the files are corrupted or missing. But I end up with 50% of the break in time being black and having the file message static in the same place.
I have opened the folder with the slides on the USB thumb drive on both a Mac and PC and checked for hidden files and don't see any. The only extraneous file was the thumbs one, which I deleted with no affect.
Anyone experience this before or know how I can get rid of this so it just cycles to the slides?
post #1164 of 1409
I purchased an open-box 60" ST30 for $1150 from HDTVGUYZ, and it arrived this afternoon via AIG. The base is thoroughly scratched up. I have already mounted it on the wall, so that's a non-issue. The cabinet is smudged in several places (as if tape has been roughly removed) and the entire cabinet is comparatively dull, faded, and not new-looking in the direct light. All of the above is barely noticeable in normal light. The screen seems perfect. The HD picture is also impressive, and everything appears to work as intended. The remote looks brand new, but the box did not include a wifi adapter. The ST30's sold by TigerDirect include one. I assume they come standard. I emailed HDTVGUYZ about the mssing dongle. Maybe they will send me one. We'll see. My house is wired with Cat 6, so I don't really need it at the moment. I may be moving soon though. Recently got engaged.The packaging left a lot to be desired.
More importantly, I used Dnice's settings. I'm getting used to the look, but my first impression is that it's slightly dim and a little too red.
How do you guys use Viera Cast? I have a Denon 3311 AVR, and I run everything through it. I connected the TV to the AVR with an Optical audio cable, and I assigned the TV its own input on my AVR. The primary input for watching TV is connected to my DirecTV Box via HDMI. It seems like there should be an easier way. I must say I prefer the Smart features on my LG BD670 DVD player to this point.
post #1165 of 1409
For a brighter picture that still looks great, Use D-nices settings, but make these 2 changes:
change HDMI Content to "graphics" and then put the panel brightness on "mid".
post #1166 of 1409
HCFR Version 3.0.4.0 was just released... primarily fixes issues when using the i1D3 and plasma displays so this is what I was waiting for. Will do a calibration either tonight or tomorrow and report back. Unfortunately it still doesn't have code for mid-life calibrations... darn it.
post #1167 of 1409
In the meantime, I'm going to try waxing the bezel with Mcguiars Ultimate Liquid Wax. Several people have reported a huge improvement. I have some at the house. If this fails, I will try some Mcguiars PlastX. I think it's used for headlight restoration among other things. A lot of posters have said it works for cleaning up the bezel too. I'm OCD about something until I get something new.
BTW...does anybody know how to check the hours on the ST30? Somebody mentioned something about a service menu in an earlier thread.
Update: Skip the PlastX. It didn't do much. Go straight for the car wax. I used Meguiar's Ultimate Liquid Wax. It's the kind that doesn't turn to dust, the kind that's safe to get on plastic. It completely eliminated the swirl marks, and it made the deep smudges practically unnoticeable unless you were really just looking for them. It also brought the rich piano blackness back. I would say the bezel scarring was reduced by 75%.
Also, I used Jimmy's setting, which seem to include the two tweaks you mentioned. It looks better. No more redness and brighter too. Very satisfied.
post #1168 of 1409
d-nice stated his settings wouldn't work right if you skipped the 100 hours of break-in with the slides. Others have reported this too and that the break-in makes a difference in his settings. Not that you have to do a break-in, but that if you want his settings it helps.
post #1169 of 1409
Thanks. My TV was an open box, so doing a break-in at this point may be moot. I was asking about the service menu because I'd like to check the hours to see how much my display was used before being "re-boxed". I'm afraid to look. lol
Update:
I found instructions on-line for accessing the service menu. Based on the info I found, the TV has 27 hours and has been powered on 19 times. I power cycled it at least ten times last night dialing in my Harmony 1000 Remote, which can be a royal pain in the butt. I guess I should avoid too much ESPN for a couple of weeks, until I break the 100 hour mark. I'd really like to avoid having another plasma with ESPNHD burnt into the right corner of the screen.
post #1170 of 1409
Originally Posted by Citivas View Post
Hi.
I'm on the same boat as you...I just started running the slides no more than 2 minutes ago. Anyways, I deleted all the files in my thumb drive but one picture kept showing up and one picture that says could not be read.
So, I just formatted the thumb drive to delete EVERYTHING on it, then dragged the break in slide into it again. Plugged it back into the TV and the slides are the only one showing. Just make sure when you drag the slide in, that they are in the proper sorting. Mine loaded up 20-1 for some reason and I had to re-sort it before I plugged it into the TV.
Anyways, again, I just got my TV, and got a few questions about it. I hooked up the internet and it said a new software is out and my current one is out of date. I got a manufacturing date of Nov 2011, should I be worried about downloading the new update and fritzing my TV? I've read a few review in Amazon of folk's TV fritzing after doing a software update.
I'll probably have more questions by this weekend as I run thru this damn 100 hr slide show.
