Originally Posted by uh2
I have this same issue. I believe it's related to the green blob issue that you see primarily on people's faces and on a grey background. I can see it only with certain colors on the XMB background. And since the background changes color automatically based on the date, it's easy to forget the issue is there.
I first fought with this when I purchased the set in Feb of this year, and Panasonic wasn't any help at all. The setting I found that seemed to 'fix' this problem was changing the HDMI settings to GRAPHICS. Some of the other color related settings were tweaked too, but I don't remember specifically which ones. I do remember that fixing the issue completely ended up throwing some of my other colors off. I've only recently come back to tweaking my settings with a combination of DNice's settings' some of the other tweaks and the MID panel brightness settings....and wow...big difference. I was never that impressed with the default DNice settings but I realized every set is different and his settings at least gave us a starting point.
Anyways...this artifact can be seen...at least on my set...with the XMB background color that looks like a yellowish brownish mustard mix. YMMV.
What settings are you using ?
:). Jimmy
