AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › RCA 1080p LCD vs 720p Plasma for gaming
post #1 of 5
Any help would be appreciated!
Which TV is better for gaming a RCA 1080p LCD or a 720p Plasma?
Thank You,
MJ
post #2 of 5
Go with plasma. Less input lag and handles motion better.
post #3 of 5
Don't like being harsh about nearly ANY product - but (personally) would not buy an RCA tv - although might TAKE one if they were giving them away....
Consumer Reports' HDTV reviews seem to often be dismissed as being "too easy" on the sets they test - but even they rate nearly all of the 2nd/3rd Tier LCDs at or near the bottom of their comparisons.
Alas, they have not recently tested an RCA - but the test results for LCDs from Magnavox, Sylvania, Philips, AOC, Auvio, ViewSonic, Insignia, Westinghouse, & Haier are so poor that it seems prudent to stick to the major lcd brands - and even some sets from THOSE manufactures fall pretty far down the list!
Assuming you are looking at a 40-42" set, would agree with the advice to try a plasma: probably either a Panasonic or - if cheap enough - a LG. (Any chance of still finding a close-out deal on a Panasonic P42U2? Would be an excellent lower cost choice.)
post #4 of 5
Originally Posted by Dierkdr View Post
Don't like being harsh about nearly ANY product - but (personally) would not buy an RCA tv - although might TAKE one if they were giving them away... Alas, they have not recently tested an RCA
That's because they don't make them anymore!
Ian
post #5 of 5
Thank you for the advice.
