I am contemplating an upgrade to my 7 channel setup that currently consists of Energy C-300 fronts and a C-C100 center and C-100 bookshelf surrounds. I am not sure what is considered an "upgrade" but I believe that my "entry level" setup needs upgraded.
The Jist:
My room is 24' L x 13' W x 7.5' ceilings. It will be a dedicated theater space with a 7.2 setup. The subs are taken care of with SVS-PC12NSD's. I want to start with the front three and go from there. I will be powering these with either the new Denon avr-3312ci or the avr-4311ci (undecided) but I know that I need to put more of my budget toward speakers. My budget for the fronts is roughly $1k but would prefer to stay at or around $600 if possible. My problem is I dont know where to go or where to start and need as much help as possible.
Thanks in advance.
The Jist:
Thanks in advance.
. If you ever have the chance to listen the the Klipsch referance line and love them, then I would suggest looking into these....
