I am looking to get a receiver with the ability to return to a specific volume level for each input when switching between sources.
I see several receivers support an initial volume level setting but the ones I have found this only applies to powering up the receiver to an initial volume. I have also seen receivers with the ability to adjust each input with a volume offset allowing consistent audio level between different sources.
I would like information on receivers or companies that support either an initial volume setting per input or possibly just a feature that returns the volume to the last volume level used for a given input.
Thank you for any help.
