Originally Posted by
SamuriHL
Anyway, using the Cyberlink Video Decoder isn't too difficult.
You need to register the CLCvd.ax file in your PDVD directory.
Then you can add it to the external filters list in MPC-HC and set it to prefer.
This next part is where a lot of people get hung up.
Double click the Cyberlink Video Decoder entry in the MPC-HC external filters window to bring up the properties.
Set it to HAM mode and click ok. I don't know who told me this next part, but, trust me, it works....
close the options dialog and immediately drag a video into the MPC-HC window to start playing it.
For whatever reason this allows HAM mode to stick.
Although, if you go back into the Cyberlink Video Decoder properties again,
it'll look like it didn't stick. The way you can tell is when a file is playing,
right click the MPC-HC window, go to filters, hold control on the keyboard,
and click the Cyberlink Video Decoder to get an extended properties page.
It should list HAM mode being used.
