Originally Posted by Qaq
pupsin, LAV audio can't connect to the audio renderer. What audio renderer do you use (see Output)? Set it to Default DirectShow Device if you prefer to bitstream compressed tracks to avr, or use ReClock if you prefer to decode audio in MPC (and uncheck bitstream options in LAV). Don't use MPC audio renderer coz it wouldn't accept floating point data (decoded) from LAV.
I had it set to System Default and I changed it to S/PDIF and it used LAV Audio. Thanks!
