AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Official harman kardon 1565,1650,2650,3650 thread
Official harman kardon 1565,1650,2650,3650 thread - Page 7
post #181 of 189
Originally Posted by Cyrano View Post
Hi - I own the 1650 and I am having a problem figuring out how to adjust the channel volume levels without losing the program I'm watching. The receiver always dumbs down into 480 res when entrring setup mode.
Is the a way to add a couple of notches of added volume to, say, the center channel w/o losing the program being watched?
Thanks for any help.
I will RTFM again, but I found nothing there before.
On my 1600 the remote has a "speaker" button in the upper right corner of the center ok button. It's white. This button brings up the speaker level adjustment mode. It will only display on the AVR unless you press the osd button.
You can also enable or disable the sub from here. Which is handy for when I want to listen to two channel with no sub.
post #182 of 189
Thanks! I had to mess around a bit but I got it. Your procedure brought up the channel on/off menu. no other button choices or manipulations brought up the levels adjustment. Then I tried the top left white button named ch. That did it. That is the levels adjustment menu.
Also I have to hit the AVR button before the white button. OSD does nothing on mine unless I am going into the setup menu.
Thanks again. I am not as happy as I would like to be with this receiver. But the sound is great. I just like a more transparent, versatile AVR.
And the OSD only works at 480 res with my receiver. I want one that does it with whatever 1080P program I am viewing.
post #183 of 189
hi, i had 2650 in box for six months. i had used for couple of days to compare with Pioneer SC-1522 at that time, it wokred fine. hooked up yesterday and facing severe HDMI handshake issues. Sources are Panny BD player and Pivos AiOS player.
AiOS display comes up only in rare cases. i can see hand-shaking on TV for some time, but then it goes away, screen blank. Hooking AiOS directly to Panny ST30 TV, it works fine. Can someone please help, I need to fly out of US in a week with AVR2650, and want to solve this before that.
post #184 of 189
one more question on 2650. is there a firmware newer than v1.0 for 2650? i could not find anything about firmware on 2650 support page here - http://www.harmankardon.com/estore/hk/us/support/spdp.jsp?pid=AVR%202650
post #185 of 189
Unfortunately I'm an idiot and installed wrong firmware on AVR3650.  Just clicked the wrong link.  AVR3600 had updates but 3650 didn't and it installed it on my 3650.  I can still change sources but nothing else works anymore, not even the menus.  Any resolution to this that anyone knows of?
Edited by reno80 - 1/23/14 at 12:02pm
post #186 of 189
Originally Posted by reno80 View Post
Unfortunately I'm an idiot as well and did the same thing.  Any resolution to this?
Originally Posted by dta721 View Post
I don't own a HK product but would think the process is similar in updating an AVR firmware.
First, how could you update the 3650 with the 3600 firmware? The 3650 has a network connector in the back. Assuming you connected the network cable, went through the instructions, then you first would have found out (i) it is latest firmware, or one is available; (ii) if one is available then you would have started the update.
Do you mean the menu gave you a bunch of model to update, and you picked the wrong one?
If so, you can repeat the same process to update with the correct model 3650 firmware?
Am I missing, or incorrect in any of the above?
As to reset the processor, an online 3650 OM page 42 would help:
http://www.harmankardon.com/resources/Brands/harmankardon/Products/ProductRelatedDocuments/en-US/OwnersManual/AVR_2650_CORE_OM_EN.pdf
post #187 of 189
I just purchased the AVR2650 ($299.99 on Newegg) as an upgrade from a Sony, which is having audio issues with my HTPC. I also liked the GUI, Zone2 support, network connectivity, and Smart Control (and quite frankly, it looks pretty slick). Now that I'm hearing so many people having issues with the newer HK line, I'm thinking I should've gone for another unit in the same price range (Yamaha 673 or similar).
Question: I read in some places that some of the audio handshake issues are resolved by firmware. However, when I go to the AVR2650 Product Support Page, I only see the option to download the manual. Where can I go do download the latest firmware for the AVR2650?
post #188 of 189
If I were you, I wouldn't mess with the firmware unless you encounter a problem. If it ain't broke, don't fix it! Seems like the act of updating firmware in itself can cause issues sometimes.
post #189 of 189
Thanks. The unit arrives tomorrow, so I'm hoping that I don't encounter any issues with my setup. However, I would still like to know where their firmware is located now (or has it been pulled for this system).
