AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Denon 1911 HDMI Problem
post #1 of 2
Hey guys, i purchased a denon 1911 recently. I currently have my samsung plasma hooked to the receiver via hdmi out, PS3 hooked to BD hdmi in and a xbox 360 hooked to the DVD hdmi in. When i select BD the ps3 works fine on a/v output. When i select DVD my xbox produces no sound or video. Anyone have an idea why this is happening? Any input will be greatly appreciated, thanks.
post #2 of 2
Check your xBox to make sure the settings are correct. Does it work connected directly to your TV? Did you buy it used or open box? If yes, then reset the microprocessor (p. 80) to reset all settings to their factory defaults.
For more information or questions on your new 1911, join us in the Denon 1911 Owner's thread.
