With the driver version 275.33 on a Gigabyte GTX 550ti, madVR 0.69, LAV CUVID 0.9, and LAV Splitter/audio 0.3, I cant get a gray bar at 17 with the AVS HD test disc flashing black bar pattern (using the mt2s file from the disc that has both the flashing black and the flashing white patterns) no matter how high I turn up brightness on my display. So it's like these settings are setting reference black to 17 rather than 16.
My display (Samsung LN52A650) is set to HDMI Black=normak (Samsung speak for 0-255), Nvidia drivers are set to 0-255 and RGB is selected (rather than YCbCr 4:4:4) in the drivers and my renderer (either madVR or EVR custom) is set to 0-255. I have a custom resolution with HD audio enabled at 23.976. This is connected through a Yamaha AVR. The same thing happens if the GPU is connected directly to the TV via HDMI, so it's not the AVR
With an ATI HD6570 and Catalyst 11.6, I can adjust brightness to barely see a flashing bar at 17 with the comparable settings as above, so this further tells me that the problem is nVidia and not my renderer, AVR or TV. The problems that I'm having with ATI are: 1) deinterlacing randomly gets switched to BOB, 2) Cyberlink HAM gives me stutter in MPC-HC with madVR, and 3) occasional lip sync glitches (23Hz default setting is actually 23.9766, which is much closer out of the box than nVidia..maybe reclock can help with this)
I really like the simplicity of LAV CUVID (HW deinterlacing on in the settings) + madVR, but I can't get the colors that I get with ATI with the minimal and logical settings.
With the nVidia setup when I set everything (display, drivers and renderer) at 16-235, I can crank up brightness so that I can see all bars flash (0 included) and manually adjust contrast on the TV to get 17 barely flashing (thus reference black is 16), BUT I thought I read somewhere that the chain needs to be 0-255 to get the benefits of madVR. If that's not true, then the only side effect I get with this is a washed out desktop, but I'll be in MediaPortal or MPC-HC 90% of the time
I'd really appreciate it if somebody could help me with getting the nvidia setup right, or advise me on the universal 16-235 settings in madVR.
Finally, is the ATI solution viable with the right choice of decoders for the right files in conjunction with reclock?
Jay
Jay
) I may be getting a slight amount of Black Crush with nVidia?
