Originally Posted by Bortonious
Are you joking me. Your use is the misapplication. Your actually feeding it a sbs file and your then surprised it can generate a good 3d image. Your actualy doing some of the work for the converter.
If I did that with my projector/ any 3D TV I wouldnt need the monoprice box at all.
This unit is sold as a 2d to 3d converter (For 2d/3DTV/3D DLP Output). Thats how it should be judged.
Anywho, I guess it has its uses, but I would suggest that yours is not the typical scenario.
In MY OPINION its not sufficient for standard 2d streams (DVD DTV XBOX etc) outputing to a projector.
Hence.........its for sale
Mkoss is using it to convert SBS into frame sequential 120Hz output. The Monoprice converter can either output frame sequential or SBS for 2D to 3D conversion. Your projector can use the SBS output since it converts it to 120hz. This is how I use it with my VIP Theatre converter. I think this converter works best with 3D ready DLP link projectors and DLP link Glasses. That is why Mkoss is so happy with it.
