I watched the 2D version not the 3D BR which I tried but it would not pass it.
When I first tried the DLP glasses on 3D version the emitter was hooked up and still functional and I was getting some kind of wierd interference causing the DLP glasses to be erratic and thought it was a distance issue with the screen I was using which is a graywolf. But when I turned off the VIP and used the monoprice for 2D to 3D DLP I didn't have a problem. If you took the glasses off the screen had a somewhat washed out appearance but with the glasses on that was not the case. You don't want to leave that function initialized unless you are using the DLP glasses. Had to invert once in the beginning. But I thought wow this is pretty good 3D on the cheap. I'm sure it will vary with other source material. But it should be fun comparing. One thing different about 3D movies is that I'm watching more than once wheras 2D I tended to watch only once.
Also it's bear researching how to get 3D side by side half which should make this device shine.
