Originally Posted by winston9332
Afraid constructive discussion on this issue has melted into illogical criticism of Onkyo.
Firstly, Onkyo very publicly announced the issue, the fix, and the offer to repair outside of warranty. It is linked from their homepage and here directly:
http://onkyousa.com/press_releases.cfm?id=215
Automatic Continuous Change of Listening Modes and/or Remote Controller Commands are not accepted
06/21/11 - Models: TX-NR708, TX-NR709, TX-NR808, TX-NR1008, TX-NR3008, TX-NR5008, PR-SC5508, HT-RC270, HT-RC370
If your receiver of the above mentioned models experiences the following : Listening modes automatically change one after another. When this problem occurs most commands will not be accepted.
Please contact our Product Support Department at (800) 229-1687, option 3, to confirm that this issue exists in your receiver. If the issue exists you will be given further direction on how to have it serviced.
***This issue will be handled for you even if you are out of warranty (this only applies to US and Canada).***
So...where in the press release does it mention a cause for the failure? Where does it mention acid? My logic is solid.
The criticism was not directed toward Onkyo. The criticism was directed toward those participating in this thread who claimed to understand the cause of the failure, claiming it was due to acid in the IDE cable. This gave credence to Onkyo's fix of replacing the cable. Because my unit had the cable and connectors replaced, and because the symptoms came back, I claim that the fix is suspect. Now, where in my reasoning is my logic failing?
