AVS › AVS Forum › A/V Control & Automation › Home Automation › Difference between these two Crestron prodigy systems.
post #1 of 13
Hello I was wondering what is the big difference between the PMC3+ PAK with the PTX3 remote verses the PMC3 PAK with newer PLX3 remote. Is there really anything different about these?
I was also wondering what are peoples toughs on the Prodigy system verses going with Control 4? Does one have more functionality then the other?
post #2 of 13
The only difference is the touch panel that comes with it, correct.
Side note with this: On most of the jobs I have done with MLX-3's and PTX-3's the clients complain about 80% of the time that there are no hard key number keys. You have to press keypad and popup a subpage with the numbers. The PLX-3 solves that by having hard number keys.
Consider how you use your system now and if this will be a problem for you. If so, get the PMC3_PAK.
As far as the differences, they vary across the board. The Prodigy system uses the 3 series processing and has the ability to add any Crestron piece so from a pure "functionality" standpoint the Prodigy blows the doors off the Control4.
I have to note, I am a little bias though.
post #3 of 13
The PLX-3 has yet to ship. It keeps being pushed back.
post #4 of 13
Is it going to be a higher end remote verses the PTX3. Also with the Prodigy system can i use the higher end C
Crestron touchscreens?
post #5 of 13
It is going to be the intro remote in the Prodigy system. The PMC3 will not work with the regular Crestron line at this time.
post #6 of 13
Sure there may be a differance, the user experiance.
"T" usually indicates touch screen and "L" Lectern or in this case not a touch screen but with a scroll-wheel.
To me it as if they are going for more of a classic remote than a touch panel, something i have been looking forward to.
New PLX3:
http://www.crestron.com/resources/pr...p=1&model=PLX3
Older PTX3
http://www.crestron.com/resources/pr...p=1&model=PTX3
post #7 of 13
So just to make sure i understand If want to use the TPS-6X or the TPMC-8X remote I would need to upgrade to a regular Crestron system?
post #8 of 13
I'm fairly certain there is a prodigy version on the tps-6x. The tpmc8x would need a prodigy expanded (xp) or regular control system.
post #9 of 13
They have not released the Prodigy version of the 6x yet either.
post #10 of 13
I thought the point of the pmc3-xp was that you could access the full Crestron range?
post #11 of 13
They are 2 diff models. PMC-3 is not the same as PMC-3 XP. I don't think it is shipping yet.
post #12 of 13
Another thing I though of which companies wireless ceiling fans and also door locks that work best with the system?
post #13 of 13
True, but it costs only a little more so idk why u wouldn't spend the extra money for the extra flexibility.
As a side question, does anyone know if the prodigy dimmer rail can dim led's?
  Back to Forum: Home Automation
