AVS › AVS Forum › Display Devices › CRT Projectors › Sharp XR30x projector with tint issues
post #1 of 2
I have a Sharp XR30x projector. Almost 2 yrs old. Still has 1700 hrs left on bulb. Recently, it started getting a tint issue after a few minutes of being on. After about 15 minutes, the tint goes 'purplish'. Turn it off and back on, picture is fine. Then about 5 minutes later, tint goes 'purplish' again.
I contacted Sharp and they wanted $80 just to see it with no promises. Does anyone have any idea what this could be and if anyone in the Tenn Tri-Cities area could fix this. Any and all help would greatly be appreciated. This projector is used in a childrens charity.
post #2 of 2
Digital projectors are designed to be completely disposable, and any reputable repair facility is going to need to cover an hour's worth of labor to look at something like an LCD projector. Unfortunately, it's usually 'yep, it's defective, and can't be repaired' which is what you pay $80 for.
There's a reason there's not a lot of digital projector repair depots that do out of warranty work, they'd go broke trying to stay in business, as the vast majority aren't economically feasible to repair.
Your best option is to look for a working unit with a dead bulb on eBay for cheap, in hopes that it will work for the remaining 1700 hours on your bulb.
  Back to Forum: CRT Projectors
