Photos Can Be Seen At Bottom Of First Post
Ongoing information for the Cambridge Audio Minx Systems.
(If you have info that can be added, please PM me)
Minx Speaker & Subwoofer Models:
Min 10 Speaker
Frequency Response: 140Hz-20kHz
Power Handling: 15-50W Recommended
Drive units: 1 x 2.25" BMR
Dimensions (H x W x D): 78 x 78 x 85mm (3.1 x 3.1 x 3.3")
Weight: 0.43kg (0.95lbs)
Available Finishes: High gloss black & High gloss white
Min 11 Speaker (Second Generation Model)
Frequency Response: 120Hz-20kHz
Power Handling: 25-200W*
Sensitivity: 85dB (2.83 Vrms input)
Weight: 0.42kg (0.93lbs)
* Using a high powered amplifier lower down its volume scale results in lower distortion and better sound. Of course if you hear a distorted sound or mechanical ‘crack’ as the speakers hit their end stops, you are playing the speakers too loud and this may cause damage. With an AVR the Min11/21 speakers should be set to ‘small’ with a crossover frequency of 140Hz. In this configuration, power handling is considerable increased.
Min 20 Speaker
Frequency Response: 130Hz-20kHz
Power Handling: 15-75W Recommended
Drive units: 2 x 2.25" BMR
Dimensions (H x W x D): 154 x78 x 85mm (6.0 x 3.1 x 3.3")
Weight: 0.75kg (1.65lbs)
Min 21 Speaker (Second Generation Model)
Sensitivity: 87dB (2.83 Vrms input)
Drive units: 1 x 2.25" BMR + 1 x 2.25" Longthrow Woofer
Weight: 0.85kg (1.88lbs)
X500 subwoofer
Power Output: 500W rms
Frequency Response: 23Hz (-6dB) - 200Hz
Crossover: Active - variable 50Hz-200Hz
Drive units: 1 x 10" subwoofer / 1 x 10" passive radiator
Dimensions (H x W x D): 365 x 320 x 350mm (14.3 x 12.6 x 13.8")
Weight: 11.7Kg (25.8lbs)
X300 subwoofer
Power Output: 300W rms
Frequency Response: 33Hz (-6dB) - 200Hz
Drive units: 1 x 8" subwoofer / 1 x 8" passive radiator
Speaker Dimensions (H x W x D) 311 x 266 x 278mm (12.4 x 10.5 x 11.0")
Weight: 7.5Kg (16.5lbs)
X200 subwoofer
Power Output: 200W rms
Frequency Response: 39Hz (-6dB) - 200Hz
Drive units: 1 x 6.5" subwoofer / 2 x 6.5" passive radiators
Dimensions (H x W x D): 219 x 210 x 222mm (8.6 x 8.3 x 8.7")
Weight: 5.0Kg (11.0lbs)
Frequency Test Files that one can download to place on a Hard/Flash drive to test their satellites and/or subwoofer (Caution: play at low levels so as to not damage your satellite speakers):
http://www.realtraps.com/test-cd.htm
Official Minx Website:
http://www.cambridgeaudio.com/series.php?SID=94
White Paper On Balanced Mode Radiator Design:
BMR_White_Paper.pdf 912k .pdf file
Previews:
http://www.howtospendit.com/#/articl...speaker-system
http://www.t3.com/news/cambridge-aud...aunches?=49319
Reviews:
S325v2: http://www.hometheater.com/content/cambridge-audio-minx-s325v2-speaker-system
S222? (Dutch review translated in English for a pair of Min 21's + X200 Subwoofer): http://www.google.com/translate?langpair=nl|en&u=http://www.alpha-audio.nl/2012/02/cambridge-audio-minx-min-21/
S212: http://www.thehifijournal.com/review...Desktop-system
S215: http://www.hometheater.com/content/c...speaker-system (Includes Measurements)
S215: http://hometheater.about.com/od/loud...uct-Review.htm
S215: http://hometheater.about.com/od/loud...to-Profile.htm (Supplementary Photo Profile & Measurements via Robert Silva's Anthem Room Correction System measured by the Anthem Room Correction System)
S215: http://www.soundandvisionmag.com/art...inx-215-system (Includes Measurements)
S215: http://www.whathifi.com/review/cambr...udio-minx-s215
S215: http://www.whathifi.com/review/cambr...-minx-s215-new (Min 11 Review June 2012 Issue)
S215: http://www.cnet.com.au/cambridge-aud...-339310461.htm
S315: http://www.dvd-home-theater.org/camb...dio-minx-s315/
S325: http://www.avguide.com/review/cambri...system-tpv-102
S325: http://hometheaterreview.com/cambrid...stem-reviewed/
S325: http://www.trustedreviews.com/cambri...ew#reviewStart
S325: http://www.whathifi.com/review/cambr...udio-minx-s325
S325: http://www.techradar.com/reviews/aud...-950843/review
S325: http://www.e-gear.com/article/review...00-subwoofer/1
S325: http://www.tone.co.nz/reviews/home-t...peakers-review
Comparison Reviews (so far):
A Min 20 review comparing the Min 10 (Dutch review translated in English): http://www.google.com/translate?langpair=nl%7Cen&u=http://www.alpha-audio.nl/2011/03/cambridge-audio-minx-min20/
A nice article asking to "Respect The Minx" with specs and info:
http://www.avguide.com/article/cambr...spect-the-minx
Chris Marten's Blog regarding BMR (Balanced Mode Radiator) drivers:
http://www.avguide.com/blog/radical-...fferent-better
The Perfect Vision Editor's Choice "Greatest Value" Category: http://www.avguide.com/review/the-pe...ems-under-2500
Edited by Perpendicular - 5/5/13 at 4:19pm
