Originally Posted by
Perpendicular
From the beginning, I seem to remember that you were the one that has his mind set on
not using one of Cambridge Audio's own X*** series Subs.
I don't understand this statement. It was in response to my questioning your advice to go with a CA sub. You are saying that I didn't want to go with the CA sub. That's consistent.
But it is not correct. Initially, the CA sub was the only sub I considered. In fact, I actually bought a CA sub:
ItsJohnB
I purchased an s212 with an additional Min 10 for the center.
But decided that the x200 would be underpowered.
So I needed a new sub, a better sub:
ItsJohnB
I need to choose a sub as well. The x300 is the easy choice. I know that there are some on this thread who feel that the CA subs are pricey and that there are better choices.
As for budget, I see no reason to go beyond the x300 ($600) since that should work fine.
So the x300 was the default choice, but I wanted to consider alternatives.
Perpendicular
Jim and I are just trying to give you other options to use as a Subwoofer with the Mins because you asked.
Which I sincerely appreciate!
Perpendicular
Obviously, there are several options that may work for you.
I was being a bit facetious (I even used a
; you can say anything on the Internet as long as you throw out some emoticons
But I did feel that there was a bit of a contradiction between the first and third quotes:
Perpendicular
I'm not sure if you want to go with that big of a driver (10" & 12") but Jim recommends three very good choices. I feel you should make a good investment in a Subwoofer without compromising. One that can go along when / if you decide to upgrade your loudspeakers.
Perpendicular
If you have $1200 to spend, why not get one of the Cambridge Audio Subs? You could add two X300s or, to dig a bit deeper for movies and Organ music, the X500. These Subs are the best choice because they are made specifically for the Min satellites. How can you go wrong here?? wink.gif
In the first one, you are telling me that I should be loudspeaker-agnostic. Not loudspeaker-unaware, as the sub must be compatible with the MInx, but get something that I would buy even if I wasn't getting the Minx and would continue to use if I changed loudspeakers.
Now, this does not necessarily preclude a CA sub, but I would guess that the number of people who buy a CA x*** sub as a standalone product for use with non-Minx loudspeakers is quite small. I consider this to be a recommendation for a non-CA sub.
In the next quote, you are telling me that my best choice is a CA sub
Perpendicular
Based on experience, I'll stand by what I previously said regarding two Subs (or more). It's better than having one. All my experiences are trial & error based.
OK, I missed the mark on this one. I thought that you were making a strong recommendation for a pair of one particular sub, rather than for dual subs in general.
Mea culpa, mea culpa, mea maxima culpa.
I'm finding lots of people in agreement with you. This is from the
Serious Audio Blog review of the SVS SB12-NSD:
"Multiple subwoofers are
absolutely necessary for high-fidelity upper bass reproduction in the home."
Perpendicular
I'm no expert. Specifically, I was only looking at test result measurements on the X200 and
don't know squat about the other two models. I have not heard any of the Cambridge Audio Subwoofers.
OK, here's where I have to question your "best choice" advice. If you want to suggest I listen to the CA subs, fine. But best choice??? As I said earlier, I do not assume that two products are the best mates simply because they are of the same brand. Products may be added to round out the product line and provide one stop shopping. One of the products may be out of the area of expertise of the company. Not saying that is the case with CA, but both being CA does not ensure the best solution.
Perpendicular
This is true, in comparison to a lot of other brands but who am I to try and tell a company how to set their price levels on what they sell?
Not expecting you to tell them how to set price levels, but this does affect the
value of the product relative to other brands and whether it is a best choice for me.
Perpendicular
It sounds like you are still speaking to me but yet you quoted Jim's comments. I'm not sure.
I was speaking to you. I was quoting Jim as another data point that the CA subs might not be my best choice. The use of "Jim" in the third person is a clue
Perpendicular
You need to pick something, anything, and audition it in your environment to see if it will work for you.
I picked something:
ItsJohnB
So, as of now, here's my plan. I get one SB12-NSD.
Perpendicular
[Neither] Jim, nor I, have the answers for you, only suggestions.
That's all I ask. I want data so that I can provide my own answer. If someone says "I feel your best choice is []
because..." that is welcome input that I can process and determine if it really is my best choice.
But when someone says "These Subs are the best choice" without providing any info, it sounds like they are trying to give me an answer!
I asked for suggestions for a sub and got some excellent recommendations from Jim and you. Investigating these further, I found where Jim indicated that one of his would be inadequate for my size room. Not faulting Jim; he answered the questions that I asked. So I asked more questions, and found that he considered all of his suggestions inadequate for my room.
As you said, only I can determine what will work for me, and I think that there is a good chance that a single SB12-NSD will work in our room at the levels at which it will be played. I'll find out. I can't determine that something will work until I get it in my home, but in some cases it may be possible to determine that something will
not work without having to get it here. I can't go to a store and audition an SVS sub, but I can try to find something comparable in terms of output, listen to that, and try to decide if it is loud enough for our purposes. If so, I'll bring the SB12 in. If I like the sound, but DO find that it can't reach the levels that we want, I might bring in two.
That would be a pretty pricey solution (at least by my standards), but seems to be my best option for something that will provide some of the lower bass in movies, be compatible with the Minx frequency range, and pass the Aesthetics Review Board.
I'm open to other suggestions for subs. When Jim suggested the SVS models, I had some pretty tight restrictions on size and cost. I'm wondering if there are other options with more relaxed requirements. I'd be particularly interested in a single sub that would work for 2700 ft^3 and still be reasonably sized.
-John
Edited by ItsJohnB - 3/25/13 at 1:19pm
