Originally Posted by
BillTiernan
Hello Jimwilson and Perpendicular. I appreciate your comments regarding Minx speakers and Orb speakers....both on this and other AVS forums.
Please help this newbie decide on my sound setup, so I can make my purchase and get on with other things in life.
Thanks for the long Post!
BillTiernan
I am about to install a 46" Panasonic plasma (Model tc p46s30) above my fireplace mantle shelf. The mantle is in the center of the long side of my 22 ft x 14 ft family room, with receiver and subwoofer located in one corner of the room. Surround sound has always annoyed me, and the explosions and background music tend to make dialog unclear.
Have you tried surround with boosting the cc by 2 db? This is what I do and should help with dialog by lowering those loud explosions at the same time.
BillTiernan
My main goal is clarity of movie dialog, with music listening the secondary priority. I don't need or want booming or low, low frequency bass, but recognize the subwoofers importance. We want to confine our left and right speakers only to sit on our mantle on either side of the TV, so the speakers are only about 4 ft apart max, so not much separation.
Actually, I use Velcro and attach the speakers directly to the television.
BillTiernan
To now, I was about to go with the Orb Classic Two system, consisting of two Orb Mod 2s and their Super8 subwoofer. But the wife hates the look of the softball shaped Orbs, and prefers the look of the 3" cube Minx small speakers and the smaller Minx subwoofer. So we are now considering the Minx S212 stereo, 2.1 system in lieu of the Orb Classic Two 2.1 system.
The lady of my house loves the look of the Minx Min 10s too.
BillTiernan
Would greatly appreciate your opinions on the following:
1. With my lack of any real speaker separation, am I just as well off staying with 2.1 sound, or am I missing significant sound improvement by not opting for 3.1 sound with a center channel? (With Orbs, I could use a Mod 1 for the left and right channels, and a Mod 2 for the center channel?)
I wouldn't say so. A 2-channel system with your speakers that close shouldn't pose a problem. Personally, I much prefer a cc for watching movies because it helps direct all the voices to the center of the screen, no matter where one sits.
BillTiernan
2. If I "settle" for 2.1 sound, is my money better spent on only a 2.1 receiver? Seems to me, the 2.1 receiver for the same money would offer more quality than a 5.1 or 7.1 receiver, because it has less complexity. But 2.1 receivers are no longer commonplace.
Gee, I've never heard of a 2.1 AVR. 5.1 has always been commonplace. I would budget a minimum of $599 for a good AVR. If you can afford up to $1,000, I'd definitly go for the Anthem MRX 300. You get a lot of bang for the buck.
BillTiernan
3. With 2.1 sound, I can pick up an Onkyo Model TX 8050 receiver for $340, with internet capability, a front USB, 80 watts per channel, and a line subwoofer out. Is this too much or not enough receiver? If the kids turn the volume way up, I don't want the speakers to blow out!
As above.
BillTiernan
4. Can you recommend an alternate receiver I should be considering for 2.1? I like the look of the Cambridge Topaz stereo receiver, but it does not appear to have the dedicated subwoofer out port. Could this receiver somehow be made to drive the subwoofer?
I don't know 2-channel integrated receivers very well. I'd stick with at least a 5.1 channel AVR in case you want to upgrade your amount of speakers, etc, in the future.
BillTiernan
5. With 3.1 sound, we are forced into a more classical 5.1 receiver, but I will only use left, right and center channels. With the Orbs, I can easily change the wiring for 3.1, but it looks like the Minx setup will not be so easy for 3.1. Can you recommend a good 5.1 receiver, if I go with 3.1 sound. I would buy the 3.1 receiver, but only wire it for 2.1.
Why would the 3.1 Minx setup be not so easy? Per my recommendation above.
BillTiernan
6. With the 5.1 receiver, will any sound quality be sacrificed by using it only in a 2.1 or 3.1 configuration?
Absolutely not. If anything, you may improve things by directing the wattage from the remaining unused channels. Like you really need it with the Minx!
BillTiernan
7. I am not an Audiophile, and don't believe in spending 75% more for a 3% improvement in sound quality. I read an article where even high end audiophiles are returning to "simple" 2.1 equipment for the purest possible music reproduction...although I realize that dialog clarity is a whole nother consideration.
For this, you would be bypassing HDMI for audio and using analog connections?
BillTiernan
8. Forgetting nitpicking about who has the better subwoofer, and given the same speaker setup, would you rate the Orbs or the Minx higher for dialog and music clarity?
Not sure, but my money is on the Minx sub.
Bill,
AVR's I recommend are Pioneer VSX-1021 $550.00 or Onkyo TX-609 $599.00.
Try not to make this any harder than it really is. Just have fun!!
