Originally Posted by
EnglishGent
If that's not possible to marry up with the Min10s/20 - do you have any recommendations on other subs ? I also had the Wharfedale SW150 on my radar.
Judging by the spec's it seems the SW150 would be even worse; the upper end of it's frequenct range is only 110Hz, so I doubt that's going to work either.
EnglishGent
I spoke to BK directly about the Gemini today and asked them about this and although the published frequency range is as you described above, they did say that "the gemini has 2 filters and one of them can be bypassed for AV use by using LFE and setting the desired frequency for the satellites through the AV receiver". Does that make it more feasible or should I still be looking at a different sub (or alternatively staying with the Gemini and looking at other satellites
Unfortunately those filters and the bypass are not going to help for this situation. They're associated to something else.
The issue is the upper range that the subwoofer can achieve while still providing usable output. Since the Mins are so tiny they need a sub that can accomodate some of the frequencies that are normally handled by the speakers themselves. To properly integrate you need a sub that can go to at least 150Hz, so when looking for potential options the frequency range should say something like 25Hz-150Hz +/-3dB. The lower number can be different -- that was just an example -- but the higher number has to be at least 150Hz in order for you to have seamless integration.
Since you're in England I'm not 100% certain what products are available to you, but a couple of potential candidates that might be worth investigating are:
XTZ Sound. I own the
99 W10.16 myself -- even did a
review -- and have found it to be a very nice subwoofer indeed. It handles music and movies with equal aplomb.
Martin Logan makes good speakers, but you'll need to spend a few dollars in order to get enough lower extension to really make movies come to life.
REL makes some nice products too, so they could be another option.
The Minx speakers are very unique, and offer an amazing sound for their size. They do have some physical limitations based upon their diminutive proportions, but if you can find a compatible sub it's probably worth the effort because the reward is some unbelievably good sound.
