So here's the sitch:
I'm creating a new listening setup in my living room by removing my bulky-yet-brilliant floorstanding KEF Q Series speakers and replacing them with a pair of Mirage Omnisat V2s that I also love, despite them being a bit more high-maintenance (proper placement is of utmost importance). This is mostly to placate the wife, though I admit I like the minimal look as well. ;-)
The one issue, as is to be expected, is bass. The Omnisats really produce great mid's and high's and an expansive sound stage, but almost no bass, so a subwoofer is needed. Here are the criteria:
* Bargain budget - $200 would be the absolute most I would want to spend and only for some outstanding value; $125 is the sweet spot.
* Small form factor - there is very little room for a cabinet (hence swapping out the KEFs), so the smaller, the better, for sure. Small size is critical.
* Large, open-floor-plan-type room with hardwood floors, approx. 30 x 20 with lots of broken space. It's basically a U-shaped room, with a stairwell and bathroom forming the middle of the U and a wall extending out a few feet from the bathroom to provide room for kitchen (at least, kitchen pantry and refrigerator) on the opposite side.
* Listening will be 100% music. Don't need at all to rattle the windows or feel the music, just want enough bass to round out the sound and to relieve the satellites. Given that, some of my listening is electronica that utilizes LFE, so good bass extension would be a big plus.
Now, here's where it gets interesting.
My home theater setup is currently running a 3.1 set up of two Mirage Omnisat V2 Floorstanding speakers, an Omnisat V2 CC, and a Def Tech ProSub 80. The Def Tech certainly has one of the best performance/size/cost ratios that I can find out there, so I'm considering moving it to my living room and finding a replacement for it in my home theater. The advantage of this is that I have no size requirements for my home theater, so I'm hoping I have more options.
So here are the parameters for a replacement HT sub:
* My home theater is in a 28 x 11 finished basement with carpeting. I find the Def Tech is currently plenty powerful for that space.
Side Note - I rarely ever turn the gain on the Def Tech above 50%, and still the neighbors tell me they can hear the rumble of my sub. From my basement. In a free-standing house. Through the ground. Into their free-standing houses. Crazy.
* Budget can get bumped up a bit, given I'm buying for my primary system. Still wouldn't want to go higher than $250.
* No size constraints.
* Almost 100% movie watching.
So my question is this - is there anything out there in the sub-$250 price point that I will like as much as my Def Tech for watching movies? Doesn't have to be better - just equally enjoyable.
Or should I keep the Def Tech where it is and find a small, cheap sub for listening to music on the main floor?
And FYI, here are a couple of quick specs on the ProSub 80:
* 8" Woofer
* 21Hz-150Hz Frequency Response
* 250 watts RMS (I think 400 watts peak? Can't confirm...)
* 12.5"h x 9.5"w x 15.25"d
It's been hard to find inexpensive subs that drop to 21Hz and run 250 watts RMS, but maybe someone can shed some light for me. :-)
Thanks in advance for your help!
* 8" Woofer
