Originally Posted by J_P_A
I was just wondering if my server needed to be supported from the the back as well. It's pretty hefty, but most of the weight is at the front where all the drives are. There are no rear support brackets on it (at least none came with it), but I'd hate to find out the hard way that it needed to be supported.
If it does not have the rear rack rail ears or accommodations for side-mounted sliding ears, then the unit is probably designed to support its own weight with just the front ears like the overwhelming majority of equipment out there. So I wouldn't worry too much about it, but you could always do a quick double-check with the manufacturer.
I always use Leviton Quickport for some reason, but other manufacturers make similar binding posts. Here is a link to the one I always use: http://www.leviton.com/OA_HTML/Produ...minisite=10251
