Thanks, As I looked more closely, I noticed that eXgo's is the same as one in that post.
post #241 of 775
6/24/11 at 4:46am
Sorry if this is the wrong thread BUT, I mistakenly changed my service menu values for the white balance/subcontrast/subbrightness. I don't think I was suppose to do that and was wondering if there was a way that I could use one of your values, or reset it to default somehow. My tv is a PNxxD550, any help is appreciated.
i could be mistaken but is there not a factory default in the service menu if some else knows maybe they can let mike know.
first off i wanted to know why samsung have left it open for anyone to update it to the d7000,surly if this was the case no one would buy a d7000,by doing this tho would this harm the tv in anyway or is it safe,only concern is warrenty if it goes boom on me,they will know i have fiddled with it,but i will worry about that if it happens!!
but anyway i have managed to get it changed after trying to figure out why i could not get into the service menu,then i read a page or so back and read the uk/eu models have to go info-menu-mute-power!! anyway i have done it and used the settings at the top of this thread,i take they a re the best ones or is there another i should be using? i had the trouble with the dvd player reverting back to hdmi 1 and i turned the anynet off and that sorted that out. while i was at it in the service menu i wanted to turn on day and night but the expert part is greyed out? didnt want to go fiddling so came out of it and inputed the settings and all seems really good,not much differance from what i had unless my eyes are screwed up,watching tennis at wimbldon in hd is nice and crisp tho. any other advise or settings if theres newer ones i should try out. one more thing what settings do you use for xbox gaming,this is where i struggle to get a good piture and i hope someone can help here. |
