Originally Posted by JustinHEMI05
OK I tried this hack, and it seems to work fine as far as the actual hack goes, but I can't seem to figure out my HDMI ports.
Basically, I run everything to my receiver and one HDMI cable from receiver to the TV. However, I know that we have to occupy an "idle" port, so I followed what one user did early in the thread...,
I bough a 1 into 2 HDMI splitter and connected this to my DVR. I have one HDMI output going to the receiver and the other to HDMI PORT 2 on the TV.
Then, I have the receiver going to HDMI PORT 4 on the TV.
This works fine when I am watching the DVR, but when I switch to Blu Ray..., which goes through the receiver, it isn't detected by the TV at HDMI port 4. This is with the DVR OFF.
So, I tried turning the DVR on to see if it had to be on to trigger the "idle" port, but it simply started displaying on the screen even though it is going to HDMI Port 2 and the TV is selected to HDMI port 4.
I hope you followed all of that.
Any suggestions?
Any suggestions?
Problem solved! I just put the splitter on the outlet of the receiver with the two splitter outs to the tv. Works fine. Can't believe I didn't think of it before LOL.
, but somehow doesn't work...
