Well I will kick it off then. Looks very good and having had the GT720 for a short while, a very versatile PJ. Kudos to the Op: GegK
"I'm sure a dedicated thread will pop up for this here very soon, but Optoma just announced an HDMI 1.4 720p DLP PJ for the States ..@ $799 SRP!"
http://www.bigpicturebigsound.com/Op...-Support.shtml
It appears the Optoma will have a VESA 3D port, so I'm guessing DLP-Link should be able to defeated, if one opted instead to use IR 3D glasses.
http://www.optomausa.com/Product_det...product_id=572[/
Too bad Acer has brought no product to market though there may be a good reason for that. I for one tire of the wait.
... might as well wait for Cedia 2011 then. (Sept. 7th I think)
Nobody makes long throw projectors anymore. I don't like the short throw ones very much, from a standpoint of the projector then is just too close to my first row of seating, which means I will notice it out of the corner of my eye, and will probably hear it's fans during any quiet scenes. I'd rather have a long throw projector, but it just seems nobody makes those anymore.
