Roger, what screen do you use in editing to set your horizontal disparity for depth?
I use a Vizio 32" Passive and sit about 5' away. It's a secondary monitor in my system. Then, when I am done I render a 3D iso 1080 24p file and play that in my HT using a Sony VPL VW90ES front projector on a 110" diagonal screen.
I often run into the problem that my 3D does not look good on the larger screen after looking flawless on the 32" screen. I haven't found a work flow to calibrate the 3D yet so what I do on the 32" vizio always looks good on the big front projector. This problem is not peculiar to wide stereobase as my 3D with the TD10 on some scenes also has trouble looking perfect on the projector.
BTW- the above Bellagio fountains YT video is now looking perfect on both but I've been working for weeks on a much longer project getting it to look good on the larger screen.
