AVS › AVS Forum › 3D Central › 3D Source Components › When small interaxials just don't cut it!
When small interaxials just don't cut it! - Page 9
post #241 of 1087
If you are going to exploit two cameras for 3D video, why not take advantage of the flexibility for audio as well? In stereo mode in both cameras you have the same set of choices - in effect you can choose between wider-spaced mic modes (two cameras left and right or two rights or two lefts) and two close-spaced mic sets that are to the left or right. In surround mode, well the possibilities are endless for choosing the best soundfield. C'mon guys, you need to go all the way here!
post #242 of 1087
Originally Posted by Frank View Post
I did adjust the images in Vegas but it didn't take much adjustment to get it perfect.
I also find that the increased parallax has the desirable effect of increasing the apparent resolution, at least for me it does.
That's an interesting observation, and I agree. Minor differences in contrast and detail between the two camcorders also might play a small part. I believe that the stereo image that is the sum of both my eyes allows me to see more clearly than either eye by itself. A contributing factor is that one of my eyes sees the world with a bit more contrast, while the other sees things with a bit more resolution. I'm not sure why that is - maybe differences in the way light hits objects, maybe just because of some inherent physiological difference, maybe a combination - but there is a perceptible difference.
post #243 of 1087
Thanks to Frank's intro shot for the test, it occurred to me that I hadn't used my Fuji W3 since I got the JVC, so I went to the St. Louis Zoo today and took a few 3D stills. The wider IA of the Fuji definitely makes 3D look more natural and pleasing to me, although I have to adjust how far I stand from my subjects. The stills from the Fuji look great. I'm going to put together some Blu-ray 3D iso's of my stuff from the last year. Thanks, Frank.
The IA's for the Fuji and the JVC should be similar when I get my stereo base extender. Unfortunately, I can't go as wide with the JVC, so some shots still won't work as well.
Don,
If I go with a dual camera rig, I think I'll do it with dual Canon's similar to Frank's. I'll probably sell my Canon HF10 and get a couple of newer Canon's that shoot at 25mbps. The HF10 is limited to only 17 or 18mbps. I'll also want tandem LANC control, like Frank's. Fortunately, I have Frank if I need answers to some of the specifics of how to put all this together.
post #244 of 1087
Hey, Frank, could you describe exactly how to get Vegas to accept the Fuji W3 mpo files (or how to pair the split left/right images)? I can't get it to work.
post #245 of 1087
What I usually do is convert the MPO to a side by side jpg with Stereo Photo Maker before importing it.
post #246 of 1087
Ha ha!
Old joke for audio techs. That doesn't work!
But for those who don't understand physics, picking up sound from separated mic sources causes echoes due to speed of sound delay factors. On stage where widely separated mics are present sound techs go to great lengths to isolate mics that are widely separated. On my tv shows I went to great lengths to to isolate mics on separated speakers even those sitting next to each other.. Besides the reverb the sound you get will also suffer phase cancellation at different frequencies that cause distortion. The best sound field is very simple, single location with directional mics near the camera for ambience, and close placed mic to speakers that are isolated to prevent pickup of other sounds. Mix the close mics with the surround mic. Achieving the isolation is the tricky part.
post #247 of 1087
Don,
Joe, I would think you would have more 3D options with two TD 1's. The lanc control has little purpose unless you are trying to do what Frank is doing with a remote control live setup. Having two 3D gives you more options in shooting with traditional 2 camera productions from two POV's. This can be especially rewarding with performances where you set one cam up in full wide and then use the other to shoot your closeups. Cut between the two.
post #248 of 1087
Originally Posted by Don Landis View Post
Joe, The lanc control has little purpose unless you are trying to do what Frank is doing with a remote control live setup.
I strongly disagree with that statement!
Long ago I tried shooting dual camera 3D without a dual camera LANC control and it was a major headache. I don't recommend it.
For example:
When using the LANC control I am able to shoot dual camera 3D video that can be uploaded to my PC and viewed immediately in 3D by loading the left and right files into Stereoscopic Player. This is not possible without the LANC control as they would be out of sync.
Another factor is that without the LANC control the cameras can be out of sync by as much as 1/2 a frame and this cannot be fixed in the editor and it can look really bad.
post #249 of 1087
I've shooting two years ago with dual Sanyo FH1 at 1080p60 (and dual kodak zi8 at 720p60) without lanc and after syncronisation in Vegas9 (temporal) StereoMovieMaker (spatial) had not bad at all 3D
Now thinking about 3D rig based on sony's camcorder HDR-CX130 with lanc and 1080p60 (or 50p)
post #250 of 1087
For example:
I must have missed something...
I thought the JVC didn't have Lanc, yet you just synced it with the Sony.
Of course, I have no intention of using Stereoscopic Player 3D and don't know what sort of limitations there is with that software. I will be editing everything with Vegas Pro and Vegas Pro has no trouble syncing multiple cameras without chase lock or Lanc but you have to know how to do that. The sync is accurate to the start of each frame. Joe may have some issues caused by his need to do some pre Vegas conversion that could cause sync problems but I doubt it. Reason is that Vegas can quantized to frames for all formats.
On another subject, I had a couple hours today free while wife was at her conference so I went to a hardware and electronics surplus store and picked up some metal and knobs to begin construction of the bench. Can you make up a chart you have found to work for IA and distance range of shooting? I believe there is one in one of my texts but haven't located it yet. The main frame I bought is aluminum channel 5 ft long and I'd like to reduce that to something I can manage for travel. 2.5 ft would be nice but not sure what range that puts the rig in. If only 1000 ft, it may not work for my project intention. I want to shoot mountain ranges and canyons 1-3 miles. If I can get that as maximum and then any distance less than that I'll be happy.
post #251 of 1087
"Ha ha!
But for those who don't understand physics, picking up sound from separated mic sources causes echoes due to speed of sound delay factors. On stage where widely separated mics are present sound techs go to great lengths to isolate mics that are widely separated. On my tv shows I went to great lengths to to isolate mics on separated speakers even those sitting next to each other.. Besides the reverb the sound you get will also suffer phase cancellation at different frequencies that cause distortion. The best sound field is very simple, single location with directional mics near the camera for ambience, and close placed mic to speakers that are isolated to prevent pickup of other sounds. Mix the close mics with the surround mic. Achieving the isolation is the tricky part."
While my suggestion was mostly tongue in cheek, leaving aside micing stages with speakers (loud speakers or human speakers?) and focusing on actual use in the field, the following is relevant:
There are three well-established microphone stereo techniques (among others) for recording natural sounds (soundscapes, crowds, musical concerts):
1. spaced omnis
If the mics in the cameras are omnidirectional mics (non-directional), then spacing the left and right mics much farther apart with two cameras recording the sounds could give a better soundfield and stereo. Distances are typically in feet, however, not inches. Good for the Grand Canyon 3D effort.
2. ORTF
This technique uses cardioid (unidirectional) mics spaced about 17 cm apart with a specific angle for each mic (110 degrees). The stereo mics on one camcorder are spaced much closer than this, so achieving a greater spread between the mics (left and right from two cameras) could result in better sound, if the camera mics are unidirectional and are angled close to 110 degrees.
3. XY or coincident
This techniques has the mic heads exactly coincide (one point) with the mics pointing at angles in different directions. I do not think that is what is used in camcorders, but it is popular among the small, high-quality audio recorders with built-in mics (Zoom, Sony). Having two cameras won't help for this technique.
post #252 of 1087
I was talking about people speaking on camera with their own mics. Over the years there have been different ways to deal with this. With people speaking, the best was developed by Sure called Intellimix. In Orchestral recordings, the mics are all up close and low gain to prevent pickup of surrounding instruments. The mix board is used to balance everything. If recording the same stage with stereo then only two mics are used and they are located center audience, commonly hung from the ceiling. The stereo rig uses two cardioid patterns aimed opposing and at 90 degrees to create a center phantom channel that is in phase.
Mark, your imaginative ways of recording stereo won't work. Been doing this too many years professionally and know how these things are done. I do not know how the internal modern mic configurations are done in consumer camcorders. Most today use two picups and DSP. I think the TD10 uses four with DSP for 5.1 but I could be wrong on that. Your methods will record sound but it will be loaded with distortion and reverb. For stereo, use directional cardioid mics, close together, aimed opposing at 90 degrees. Or, make life easy and just buy the stereo mics.
Bottom line, wide separated stereo mics to improve stereo separation is not just a myth, it is goofy dumb! But not to be too hard on this there is one special case where this works. It is when you only have one sound source, AND you can feed the two mics into a SURE Intellimix.
post #253 of 1087
Apparently your definition of "sync" is different than mine!
The cameras were obviously not in sync with each other.
I used Vegas to get them within one frame of each other but that's the best I could do. They could easily be out of sync by 16.6 milliseconds or more.
Vegas of course, has no way of knowing the two video streams were taken at different moments in time.
One of the nice things about the LANC controller is it displays the sync error down to 10 microseconds. I never let the cameras get out of "sync" by more then 5 milliseconds because I know from my own experience that it can make the video hard to watch.
For what it's worth, I probably use that particular piece of software more then any other cause it's so incredibly useful. Your mileage may vary.
post #254 of 1087
"For stereo, use directional cardioid mics, close together, aimed opposing at 90 degrees."
That is just one stereo technique, and it is neither the best nor used the most (actually hardly at all) by audio engineers who specialize in recording sound for a living.
Don, ORTF and spaced omnis are standard methods of recording stereo with two mics. What is hanging from the ceiling for concert recordings could be either an ORTF configuration, spaced omnis or even a "Decca Tree," which has three mics, the middle to fill the hole from spaced omnis. There is also Blumlein, mid-side. . Some companies use scores of mics for different sections as you say, but I am just talking about two-microphone stereo techniques. And placement matters a lot too. Most professionals I know prefer two-mic techniques for recording natural acoustic music, but often recording live concerts dictates closed-space multiple mics because of an obsession with quiet.
Two mics at 90 degrees with some kind of spacing (if no spacing it's likely XY, but that is rare) is not a well-respected stereo technique and I do not know any professional engineer who does that. I did not say anything about "separation" for the sound field, just the mic spacing to achieve good sound, as measured by multiple dimensions directionality, frequency response, depth, width.
Now, whether these classic stereo, two mic techniques will work with combinations of camcorders' mics, I agree we can't know without knowing their specs. But I know what I need to find out. Anyway, this is just fun to think about. One could just more easily just set up two mics and plug them in, as you say, but certainly not with an arbitrary spacing at 90 degrees! And cardiod has limited bottom frequency response compared to omnis, and often more noise at a similar price point.
post #255 of 1087
Frank. You are absolutely correct that the editor doesn't know that the two videos are not framed at the same moment in time, UNLESS, you provide a reference. In professional video that would be timecode and genlock. However, neither consumer camcorder has this reference. The pro versions do provide time code that can be used to get frame accurate video. SO, absent the timecode, what is done for a reference is the use of audio that is "glued" to the video. Thus my prior references to the clapboard. The simultaneous pop sound plus the visual of the boards coming together is as old as nagra sound recording for film and the method is still a rather accurate procedure to get the two close enough. There have been references to the use of a photo strobe flash as the light is less than a frame of video in duration but this method has been shown to be less accurate than sound. In Vegas the use of sound waveforms on the two cams of a sound pulse of short duration can be quite accurate. Still, I agree, that it will never be as accurate as two genlocked cameras. The need for the two cameras to be that close may not be necessary for amateur video. The work you did looks just great to me and was quite surprisingly close. If you feel your shoot was horribly out of sync then I think you need to get your eyes examined again. We're not planning to broadcast this stuff you know.
Also, LANC is a rather mysterious signal set. I've had great success making a converter for LANC time code convert to LTC AND GENLOCK to sync broadcast cameras to a consumer camcorder's LANC output. It doesn't surprise me you have found equipment that can do the same. If I complete the task of building the twin TD10 bench and it fails sync as you suggest, I can always buy the device you are using and resolve the problem. But, your results tell me I won't need that.
post #256 of 1087
Thanks Don but I've been doing this quite a while and I think I know a lot more about it then you apparently think I do.
I wasn't suggesting that I observed the sync error in the video clip, I was stating that there is a sync error because there is always a sync error whether you observe it or not.
In this particular video clip I was fairly lucky as the sync timing was not noticeably off (to me and you) but it just as easily could have been off enough to make the video hard to watch.
That's what I'm trying to explain to you.
Without gen-locked cameras or at least a LANC controller which displays the sync error, you're just lucky if the 3D video is usable.
I could fairly easily demonstrate this by deliberately shooting a 3D video with the timing off by 10 or more milliseconds but do I really need to do it?
post #257 of 1087
Obviously, I haven't used LANC with dual cameras, but it seems to me that a huge problem would be lining up any shot that used anything other than max or minimum zoom. If you want to create a shot that doesn't zoom in or out while live (the vast majority of shots I'd want to use), isn't it very difficult without LANC to set exactly the same zoom range for both cameras? This would be a problem completely unrelatd to genlock.
post #258 of 1087
Obviously, I haven't used LANC with dual cameras, but it seems to me that a huge problem would be lining up any shot that used anything other than max or minimum zoom. If you want to create a shot that doesn't zoom at all (the vast majority of shots I'd want to use), isn't it very difficult without LANC to set exactly the same zoom range for both cameras? This would be a problem completely unrelatd to genlock.
Good point. Forget using zoom without a dual camera LANC control.
post #259 of 1087
Keeping in mind that I have read virtually nothing about the "proper" way to shoot 3D:
My general rule of my thumbs is:
Assuming nothing in the foreground to cause excessive parallax;
Increase the interaxial distance from normal eye spacing 2.75"(my opinion only) proportional to the zoom factor. I.E. 10 x zoom = 27.5 inches IA.
My canons have 15X zoom so that would be 15 * 2.75" = 41.25 inches. Increasing IA beyond that causes the dwarfism effect. (objects seem too small and unnatural - which I enjoy occasionally)
post #260 of 1087
Also I am no expert but have given this some thought. We want an angle with vertex on the subject in the foreground and 2.5 inches (my estimate) eye distance at the point where the zoom pretends to be. I think Frank's numbers are right, to multiply the standard ia (but maybe of 2.5) by the zoom factor. By zoom, of course I mean anything different from a normal lens emulating the eye.
If one runs a constant speed zoom, the ia could be changed also at a constant speed whenever holding down the zoom button, so the mechanics or electronics need not be complicated.
Also, I don't think the ia distance needs to be completely consistent from shot to shot, but a rig could pretty readily recalibrate itself at each extreme of zoom and ia distance, when it can't go any further no matter how much we mash that button.
post #261 of 1087
One more thing. I like to keep the cameras parallel for simplicity, but if you want convergence, just build the rig to shift the cameras along an arc instead of a straight line.
post #262 of 1087
I got an opportunity to "play" with bench rigs that did adjust the angle of the cameras but the guy there explaining how that worked said the arc of adjustment is not the same along the bench travel. it has to vary depending on the distance between the cameras. Since a bench would not be circular but more parabolic ( angle less as the IA distance increases), what they did is have the two cams on a servos that automatically adjusted the angle as the cameras changed distance along the bench. This was really complex when the cameras used under-thru configuration. Aside from being complex, the rig was quite expensive.
But there really is an easier way which is the keystone adjustments in the Vegas 3D stereoscopic effect. Just keep the bench straight and the cameras parallel and use Vegas to calibrate the images convergence.
post #263 of 1087
Joe- I agree and that is why I feel that when using twin cameras it is quite important to use the proper tool to get things aligned properly. I know Frank believes the LANC is the best tool but having sat through the Sony class on how to do this, the process is actually quite easy with Vegas. Vegas Pro has the tool to align the two images both with automatic and manually. The adjustment monitor is your eyes and brain. Even if the shot has a change in z distance the adjustments can be corrected along a keyframe timeline. If the shooting zoom with twin cams is not changed during the shooting but the zoom locked down to initial calibrated framing each, then there should be no need for LANC to keep both zoom lenses in sync. I have no experience with dual camera control using LANC so I have no idea how accurate the zoom sync would be. I would be amazed if the zoom on each camera tracked accurately. In Franks test he had to carefully manually adjust the JVC / Sony so that the image was about the same. I think he did an amazing job of that as the two looked to be exact. Also I felt the exposure and color balance looked amazingly the same. It certainly shows that two dissimilar camcorders can be used to create a 3D image.
BTW- In an over through or under through setup the method of calibration is to set the cams for zero IA and super the cams images with transparency, calibrate the zoom on each for exact match and then the zoom is locked down. the cams are then spread to the desired IA on the bench.
Frank- OK I understand your sync comment better now. You claim you got lucky but I think the timing is actually easier than you think as long as one has a reference to calibrate the videos with. I haven't done this with 3D but I have with lip syncing for music videos and it was not that hard to do except that some of the cameras in the project were not the same so the audio / video tracking was off. The easy way here was to unlink audio and video and with quantizing to frames off, slide the audio a few milliseconds and re group the sound to the video then match up quantizing to video frames. I don't see why this will not work with 3D. But at this point it is a hypothesis and until I test it, it remains as such. If it fails and your Lanc controller system works I can always spring for that.
First things first, I need to build the bench.
post #264 of 1087
I think I like the idea of you proving it won't work.
Would you like me to send you a short left and right 3D video clip with the sync off by 15 or so milliseconds so you can try to fix it with Vegas?
post #265 of 1087
I didn't sit through the Sony class but I know how to do it and it can be quite tedious and time consuming and of course every adjustment you make to compensate for the lack of a LANC controller cost you not only in time but in image quality as every adjustment Vegas makes is reducing the quality to some degree.
I really don't understand your resistance to the LANC control. It can't be cost.
post #266 of 1087
Frank- I didn't say I am against adding the Lanc controller. I said I would add it if the testing proved it was an advantage. Your demonstration between the two JVC and Sony clearly showed it can work without the controller. It seems that using two Sony TD10's will be even easier to align and adjust as well as using Vegas to do the tweaking.
I do know how difficult timing the alignment of each left and right video can be without a reference, but using one or the other or both sound track plus a "clap board" sync reference, my experience has been that it is not that difficult. In my multiple camera productions, my timing sync just used LTC time code and it was very quick and easy to align using nothing but time code in DF mode. I had 4 cameras on many of my TV shows. They were all started at different times but the timecode was chase locked, yet only two using identical DVCAM recorders were in sync, another using a different DVCAM recorder was always off by exactly 3 frames and a fourth was a hard drive recorder was out by 1 frame. Once I knew the timing adjustments, I made them for ever clip and the the error correction factors always held, year after year of shooting. Now I know that you say the calibration needs to be more accurate than what I did but I will have to see if that is an absolute requirement or just your guess that it is. Additionally, I need to see what the cost of the Lanc device is, it is works like the magic you claim and not expensive, I'll just spring for it. Unlike you, I DO have a budget and need to watch the money carefully. I'm retired with little supplemental income from my business and I work with a budget. I am thankful that you are doing such a generous job of testing these things so I don't have to. I do have to be careful, however as not everything you do and every end goal I have is a match to yours. Therefore some things may not be necessary in my end use. e.g I have no use for a live windowed display on a laptop or a checkerboard display monitor. MY goal is still to shoot some very large panoramic landscapes and maybe some fireworks. I also need to take the 3D package into the public and not have it be overly bulky or draw unusual attention.
Ran across this info some here may find interesting:
http://www.technica3d.com/3D-alignment-chart/
post #267 of 1087
Guess what I'm currently recording with my wide I.A.?
post #268 of 1087
Frank- Is this the Lanc device you are using? For the Sony, did you need to find your own cable adapters for connecting to the TD10? The Lanc port on the TD10 is not the older style stereo mini plug / jack but a D shell 11 pin I recall connector that also contains AV signals.
I read through the setup manual on this device and it seems it is not as simple to use either. A bit pricey too.
Can't make out what bird that is in the tree, A Bald Eagle maybe? Could be a crow too as the detail in the thread image is not enough to tell.
post #269 of 1087
It's a bald eagle in my backyard and I'm still recording it.
I think the video will be awesome. Can't wait to see it.
That is the LANC controller I'm using and yes it is pricey. That's one reason I asked my friend to design a cheaper better version.
Our version only has about 10 dollars worth of parts in it.
Gotta get back to my eagle recording.
post #270 of 1087
Most of the price is likely in the R&D recovery. Hope your guy can do better in price.
By the description on the web page, there are additional factors to consider they claim to resolve, such as exposure sync and shutter speed sync. I admit I hadn't thought of those issues but probably when out of sync, could be additional major detractors from a 3D stereographic rendering.
So building a 3D stereo bench for wide IA using a second TD10 could get more expensive than I thought-
Second TD10-- Budget for $1150
LANC sync-- Budget $435
2 AV/r to LANC jack adapters $50
Metal and other hardware-- $50
Total $1685
  Back to Forum: 3D Source Components
