Somehow I have overseen that posting. Do not know why, only Franks comment made me look up and then I have seen it.
Well, at least it gives me some objective information how this first couple behaves - and I will be able to compare it to the second couple. Yes, it could be done easier maybe, but it is also part of a learn process.
I see here a clear advantage. Since the mechanical precision is better, I think that you able to get more reproduceable results. MAYBE. You know, from a technical perspective you have a system with a lot of bottlenecks and constrains. When you clear a bottleneck, you will run into the next one. So the ballheads generate the better mechanical precision - but I do not know yet if that is important really, since maybe the next bottleneck will prevent us to utilize that benefit. Or it helps us. Whatever the next bottleneck is - maybe the precision of the optics, maybe of the Igus parts - I do not know yet. But my idea was to get a higher precision. If it turns out that it is worth nothing - well, then I have here the Manfrotto parts too.
Well, that is not impossible. Maybe I can shoot some photos.
But with regard to the results: my interpretation of the figures - and the most impressive result was the test with the simple cross in - is that with that cameras it is not able to end up with the optical pairment of the two cameras. At least not in zoom.
Sorry to hear that.
Yes, I assume that you are right here. There will always be some standard deviation, especially at the edge of the system. And with full zoom we are at such an edge. Like you I expect that a pair of cameras must have a standard deviation in full zoom. The question will be how large that the variance is for the new pair - since I am not able to purchase TD10s in an endless way.
But my error was that I purchased the two cameras with a distance of one year - and there my be changes in the production or they use other settings.... and then the TD10 is still fine if you use it as intended, but not to use this unit in a camera pair
I have ordered another TD10, and I will see what are the deviations with another new camera. I have ordered it from the same dealer, who has still 3 pieces left (and since the turnover with the old TD10 is still limited yet, there is a good chance that this second camera is from the same production charge as the other one - but I will see that after some testing). But it will take the dealer 3-4 days, since the camera is not in Vienna yet.
Since I have now some experience how to measure and compare two cameras, the next comparision should work fast. At least to know it the new pair behaves better in terms of synchronisation and optical geometrics as the old pair.
And if the new pair works fine, well then I should be able to compare also the effect of the Manfrotto 323 and the ballheads.
Originally Posted by Don Landis
I can see the target fine you nicely documented. An excellent piece of work if it had any meaning to resolve the issue you are experiencing. Unfortunately, it appears more to be a precise measurement of a procedure that I feel doesn't work. A procedure that's difficult and and time consuming to align in the field and uses hardware that is bigger and heavier than necessary.
If your ball heads could demonstrate a better way to get calibration and more precise settings for disparity between the two cameras, that once set in the shop never need calibrated again, I would be game to reorder the ball heads and give them another try. But I don't see any advantage. Regardless how impressive your charting efforts are, it doesn't resolve the primary goal to make a system that is light weight, portable, accurate, and repeatability for field setup.
Sorry to hear that.
Originally Posted by Frank
Over the last 3 years I have experimented with a lot of combinations of dual camcorder rigs involving over 15 camcorders.
They all had one thing in common which is an optical deviation throughout the zoom range. I suspect the best chance of getting two that are extremely similar is to make sure their serial numbers are consecutive or as close as possible to each other.
) I have no reason to use dual TD-10s.
