AVS › AVS Forum › 3D Central › 3D Source Components › When small interaxials just don't cut it!
When small interaxials just don't cut it! - Page 28
post #811 of 1087
I see it has been sold.
email rclark@intervideo24.com
phone 818-843-3624
2211 N. Hollywood Way - Burbank, California - 91505 - United States
Why don't you call them and find out. They bought it from somewhere. Looks like this may be what you need.
At least we know this technology exists.
post #812 of 1087
phone 818-843-3624
I'm the one who bought it.....
post #813 of 1087
Congratulations, I hope! Looking forward to hearing your impressions on it. Especially how portable it is.
post #814 of 1087
Then I am keen to hear something about your experiences with this tool. Especially how it performs in synchronisation.
But how will you use that in the field? Looks fine for a studio...but for the field?
post #815 of 1087
Portability is not an issue for me but at least I'll be able to see if might be practical to use in the field.
At the moment I plan on using it to transmit high definition 3D from my dual camera setup outside, something I can not currently do.
Of course I will be checking the feasibility of using it in conjunction with my gyro stabilized unit in my boat.
post #816 of 1087
I tried shooting some 3D test video yesterday where I managed to get my cameras out of sync by 5 to 7 ms.
Unfortunately, most of the wildlife was taking the day off.
Perhaps today I'll have better luck.
post #817 of 1087
The info online was pretty sparse. When you get that synchronizer in, please post any reference to the manufacturer from any documentation on it. I'm guessing this box may be made in Europe.
Wolfgang- on your stefra LANC controller, where do you read the mis-sync in ms? The only digital readout on that controller seems to be just a single digit display to let you know what mode you are in. The web site shows a single digit 3 in the pictures of the device. The Lanc Shepherd has a larger LCD screen that gives the mis-sync in a fraction as well as a decimal number in miliseconds to 3 decimal places.
post #818 of 1087
Right after ordering it I got an e-mail from seller telling me it would ship Monday and asking what resolution I wanted it preset for.
I responded by asking if I can set it later.
No response as of yet.
post #819 of 1087
Well I don't have anything ready to upload yet, either, but I obtained an interesting result from shooting an anniversary clock (or "torsion pendulum clock") with my Sony TD10.
In Vegas, I introduced a one frame offset between Left and Right and rendered a half-width side-by side file. In other software (Virtualdub) I harvested only every 4th frame. This made the effective offset only 1/4 of a frame. I defined the final framerate as 23.976fps.
I wasn't expecting the result I obtained. When moving in one direction, the balls of the anniversary clock appeared to be orbiting the central spindle so closely they were almost touching it. When the balls changed direction, they appeared to orbit at an exaggerated distance, even extending outside the transparent dome!
A marked effect for only a quarter-frame time offset.
I may reshoot this and upload it.
post #820 of 1087
You push the on/off buttom, and get a display information:
There is the range 0ms up to 1ms in 0.1 ms steps:
"." shows a missync below 1 ms
"3." means that the missync is between 0.2 ms and 0.3 ms
Here you have the steps ".", "1.", "2.", "3." and so on.
For the range 1ms up to 4ms you see the number without the ".", so "1", "2", "3" or "4". Also here, "4" for example means that the missync is between 3ms and 4ms
For a missync larger then 4ms the unit displays "E" (error). The controler works up to 10 ms(PAL) and 8.34 ms (NTSC) missync.
The manual states that a missync > 1/250 s = 4ms is too bad for streesocopic recording. But Werner Bloos told me that he would not accept a missync > 1ms.
post #821 of 1087
Thanks, for that explanation. Seems awfully cryptic. The Lanc shepherd is so simple by comparison.
Hey Frank, Just got back from grocery shopping and you just cost me $6.99 for a bag of peanuts. Wife just had to buy a big bag after seeing your video. Hope she doesn't send me off to find a bucket to match yours. Oh well, she didn't ask for a Chevy Volt at least.
post #822 of 1087
No, it is not cryptical. After short trying it becomes quite clear how to read that.
I have tried today to finalize the optical adjustment of my camera pair. Seems quite good, what I know now for sure is that the ballheads keep the adjustment very stable, even if I take the slider down from the igus base, and even if I take down the cameras from the ballheads. Had to decide if I adjust it in full zoom or in full wide angel, and came to the conclusion that it is better to do that in wide angel - since here I shoot and there is still a limited variance at the y-axis in full wide angel if I do the adjustment in full zoom. Similar to what Frank has shown in his video zooming full in.
post #823 of 1087
When I did the alignment of the slide tables with the shims between the 323 and the plate, almost 8 months ago now, I finalized my system at full zoom. It holds accurate in full wide too. Still, my Vegas auto correction for alignment averages .0035 give or take for vertical correction. I was thinking I should recheck the shims again.
If you accidentally unlock the ballheads you lost all your calibrations don't you? That's why I don't like them for this application. They are designed to be readjusted and what I want is a semi permanent alignment. Less I need to do in the field.
Anyway, I'm working on my hyper stereo rig for the really big stage. Got the second tripod in on Saturday and have it all set now with a laser transit attachment. Forgot to order another 323 for the head so I can swap out the cams easily. Ordered some 50 ft extension cables for the sync controller, but I'll still be using sound sync to add the markers. since I'll be too far away to use a clap board for both cameras, I'll be using some small two way radios to send sound sync to the other camera. Haven't tested the latency on that yet. My biggest concern is the UV haze since the distances will be so great. Bryce canyon was pretty clean but the distances there were about 15 miles maximum. I suspect this new location will have subject distances of 25 to 30 miles. I also plan to shoot wider angle 16mm lens and move in closer if the haze is problematic.
post #824 of 1087
Sure, it is similar to the 323 shims. If you screw them down you loose your calibration - and that is true for both the ballheads and the screws.
The optical behaviour is similar to what Frank has shown in his video (where he showed a drive from full wide-angel to full zoom). There is a small vertical variance, for all the systems that I have tested by now. If I allign the system in the full zoom, I find a vertical variance in wide angel - something of 1.5 to 2%. If I aling the system in full wideangel, I see that vertical variance in full zoom. So I had to decide where to calibrate the system - and I do that for the full wide angle since that is the range where we tend to shoot our 3D videos.
The largest correction requirement that I see from the automatics in Vegas is the rotation. That is something where I expect the shims to be superior. But I have not to repeat the calibration every day, since it stays constant. And if necessary I am able to do a new calibration very fast, since that is foreseen by the system.
Maybe important for hyperstereo: I am able both to converge the system, but also to shoot with parallel axis - since there is a separte screw that allows you to adjust the individually.
post #825 of 1087
Parallel vs convergence is the only adjustment I make in the field and I designed the system that way. You are right that rotation and keystone corrections in my clips are near perfect. At full zoom, I get .0015 max on rotation and similar on keystone. It's true that most of my shooting I found to be at full wide to 3:1 zoom but I do some shots with 10:1 too. There is no variance between full zoom and full wide if I do the final parallel at full zoom. I can't recall trying convergence on a target at full wide. I think convergence on a distant target is more difficult, but then I'm not sure cameras are really parallel when I think they are either, after all the distances are so great. Full wide is very forgiving on accuracy.
post #826 of 1087
The intersting point is: you can apply the automatic correction of Vegas also to a zoom drive - I apply the automatic 3 times and have a full correction. Fair enough for the cases where I go into more zoom.
For the convergence/parallel discussion: I am interesting to hear your experience with a hyper-hyper stereo base. When you have 50 or 100 m. If you would not converge here, you will loose a lot from the video left and right. Given the fact that we can correct it in the postpro in a perfect way, it is maybe less important how we shoot - even if it has an impact to the depth bracket and to the amount of horizontal correction.
I wish I would have the time to shoot more - since now I am ready with all the long preparation. One of the camera has been returned today to the dealer, I still have 3 cameras - and at the moment I think it is not an ideal solution, but a solution that will work fine.
post #827 of 1087
Regarding the 3D combiner I bought off Ebay:
It weighs about a pound without the box and a little less then 2 with it.
It runs on 12 volts D.C.
They have two more.
This is what I was told by the guy setting the presets for me.
post #828 of 1087
Have you been able to make some tests Frank? Does it work for you to multiplex two streams to 3D using hdmi?
Edited by Wolfgang S. - 6/7/12 at 3:05am
post #829 of 1087
Rest assured that you guys will be the first to know about it (other then me) when I check it out.
If I had two, I wouldn't have any problem shipping an extra one most anywhere.wink.gif
post #830 of 1087
Thank you for the offer. I had some short email conversation - and they would send the box also to Europe. The question is what the box is able to do really. Because here in Europe that will be even more expensive - you pay the transport and for sure the additional tax. So I would like to learn what the box is able to do first.
post #831 of 1087
I just acquired two new Canon HF G10 camcorders and mounted them on my small bench. I aligned them with my laser cross hair. The alignment is spot on throughout the entire 10X zoom range.
I bought these specific camcorders for their extremely good low light characteristics.
Preliminary test results are very positive.
I am attempting to mount them with a minimum IA of 3.5 inches and it isn't easy because the LANC port and HDMI port are on the side. I need to access both HDMI ports to feed the combiner and small right angle mini HDMI connectors are hard to find.
post #832 of 1087
post #833 of 1087
Don to the rescue!!
Thanks...
I had already ordered a few different types to try that may or may not work.
The Cineroid 27" front type looks like exactly what I need as it is inverted.smile.gif
P.S. Unfortunately using the inverted connector will require that I remove the hinged cover from the camcorder.
Edited by Frank - 6/10/12 at 9:31am
post #834 of 1087
Frank, what are the connections that are offered by the stereo combiner? Can you feed in two times 2D hdmi, and is that convertetd to a 3D preview with an hdmi out?
And I am really keen to understand how the synchronisation work - is that a box that is able to force synchronisation with lanc or A/V R?
post #835 of 1087
It should use frame store technology, genlock and Lanc unnecessary to sync the signals. I'm curious as to how Frank will record the combined result. Lanc may still be important as a zoom controller.
post #836 of 1087
It has dual DVI inputs and one DVI output.
I was told that it wasn't originally built for this use but the company that I bought it from realized it could be used for this purpose which is why it uses DVI I suppose.
The outputs can be set to frame compatible side by side or top and bottom and most any frame rate.
It arrives today and I'll let you in on all the specifics after I have a chance to test it.
post #837 of 1087
Do you have a Blackmagic design capture card for recording the output?
post #838 of 1087
I do in fact have one. I also have an Avermedia and another Avermedia coming that's compatible with Stereoscopic Player.
Of course it doesn't matter that much since I'll be using the camcorders themselves to record both streams.
post #839 of 1087
But for 3D you will need specific cards from Blackmagic. There is only the HD Extreme 3D or the Ultrastudio 3D, I think.
post #840 of 1087
The output from the combiner is frame compatible 3D, not HDMI 1.4 3D so any 1080 HD capture device is compatible with it.
  Back to Forum: 3D Source Components
