Hi all!
This is/was my first build and probably more ambitious than it should have been.I definitely leaped in with both feet. It was fun, exciting and trying.
Maelstrom 21"
Russian Birch 3/4" and 1/2".
Volume is 10 cubic feet.
Size is 48" x 28" x 18.5"
an MFW-15 next to the Maelstrom.
Inside with wall lined with sound dampening material and polyfil. I wanted to test it before I covered it.
So at this point I tested the sub and unfortunately I ended up with a bad driver.
But I continued on with the project.
Staining russian birch is dumb. I wont do it again, at least not with a dark stain. Takes forever and the wood doesn't want the stain.
Final coat made it nice and dark.
Off she goes to the upholsterer.
and then she came back.
I don't have a working driver, so no numbers to post. I will be powering with a EP4000. This was my first time using a table saw or router, so it was definitely a learning processes. It definitely has WAF acceptance even though I only have a GF, but she play the wife role well.
I like the height and it is a beast, but it's comfortable to put my feet up on and when I did the original testing, it didn't vibrate much at all. I used a dark chocolate color that's a leather/faux leather mix. Interesting material, but feels nice and I think looks pretty good.
Maelstrom 21"
