I have a Denon 1611 AVR. It has two "remote control" jacks on the back. "In" and "Out" for "Room to Room". The manual says you can use the "in" for a IR extender and the "out" to control a zone2 component.
I also have a 90s tapedeck. It's a Kenwood with two "system control" jacks, which are otherwise unlabeled except for the XS icon.
My question is, if I plug the Out from the Denon into the tape deck, will I be able to control the tape deck with the Denon remote (or a harmony remote)?
I imagine the way to find out is just to plug it in and see what happens, but I wanted to see if anyone knew firsthand if it would work. Or if I could cause any damage plugging the two together. Finally, I'm not sure what sort of cable I need. It appears to be a 1/8" minijack. Does it need to be mono or stereo or does it not matter (or is it another type of cable)?
