AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The Official Yamaha RX-V867 Owners Thread
The Official Yamaha RX-V867 Owners Thread - Page 37
post #1081 of 1093
Hi all
I have been a happy user of the Yamaha RX-V867 for a little over 2 years, yep there lies the problem, the warranty is up.
3 days ago, the receiver started turning off randomly/intermittently. It only did it a couple times, so I "reset" the receiver and it seemed to work fine for a couple days. Then yesterday it started again, and more frequently, today it is almost avery 5 minutes.
I have checked and re-connected all the speakers, disconnected the surround and center, and even used a different set of speakers with no luck. I called Yamaha, well since I am posting here you can guess how that went.
I was wondering if anyone had a similar issue or in the alternative any advice on repair. The closest Yamaha service center is 80 miles away, but a local repair shop says they repair Yamaha amps.
post #1082 of 1093
My guess is some sort of protection issue, but I don't know how to diagnose those. I had a Sony that would shut itself off after going into protect mode because it was getting to hot, in its opinion.
post #1083 of 1093
Originally Posted by jnhusker View Post
Hi all
That sucks. On one hand it still get updates, and I like mine. On the other hand it is discontinued. I guess you have to flip a coin to update or repair. I would repair but research alternatives. As usual, it's a $$$ issue.
post #1084 of 1093
My experience with Yamaha AVR's (multiple different models) powering themselves off apparently as part of their internal "overload protection circuitry" seems to be related to either (a) sudden surge, like perhaps from power on/off of externally connected devices, or (b) very high level from source input devbice, or (c) output volume to speakers level set very loud or "no load".
But these were easily repeatable, and it was obvious what had been done or occurred to trigger the sudden power-off shutdown of the Yamaha.
Nothing "random".
post #1085 of 1093
Replace all the speaker wire. What do you have to lose? Start with stereo, progress from there.
post #1086 of 1093
Hello,
Im looking for a thread that may discuss the RX V867 HDMI out problems and/or system reset to factory settings.
could you direct me.
thanks, Kyle
post #1087 of 1093
Originally Posted by meritks View Post
Hello,
thanks, Kyle
Reset on pages 118 through 120. More information on other thread:
http://www.avsforum.com/t/1258247/official-yamaha-rx-v667-rx-v767-thread/0_50
Use the search thread function.
post #1088 of 1093
Question about ARC:
Just purchased a new plasma (panasonic S60). I have all my input sources (cable box, xbox, ps3) connected to my 867 via HDMI and one HDMI cable going out from my receiver to the S60. There's no option on the S60 to turn off the speakers so I have the volume set to 0.
But I've found myself using the youtube app on the TV and thus using the speakers on the TV. Thought I could use the ARC function to push the audio from the youtube app to my receiver but I'm not sure how to configure it (was a bit confused by the manual for the receiver).
Would I need to use a 2nd HDMI cable from the TV going into a free HDMI input on the receiver? I tried this method and enabled it in the setup menu but got no audio from the receiver.
Any advice??
post #1089 of 1093
No. ARC works over the same cable used to feed video to the TV from the AVR. That's why it is called the Audio Return Channel.
Most sets only have one HDMI input that can be used for ARC. Also, you need to enable HDMI Control on both the TV and the receiver. The manuals will have instructions. Or, you can simply use an optical cable from the TV to the AVR. Optical is simpler to set up and works without any of the complications that sometimes plague HDMI Control.
post #1090 of 1093
Right before I read this, I checked the settings for the tv and hdmi 2 is the one that supports arc (no idea why it's not hdmi 1). But got the same result as before...no audio from the receiver.
Think I'll try your suggestion and use an optical cable.
post #1091 of 1093
Any advice??
http://service.us.panasonic.com/OPERMANPDF/E-HELP_S60.PDF
Page 114. Just speculation.
post #1092 of 1093
Thank you!
post #1093 of 1093
Actually audio should only be passed in pass trough mode (I don't use it and don't remember if the 867 has it). By default audio is stripped from the hdmi signal, you must have turned it on.
