AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The Official Yamaha RX-V867 Owners Thread
The Official Yamaha RX-V867 Owners Thread - Page 30
post #871 of 1085
Originally Posted by mchiasson View Post
I have a quick question about the Sirius IR input on the 867, and I hope someone can help.
I just finished setting up my father-in-law's receiver on his network, and we tried to listen to his XM account. We logged in using his account as well as my account, as we both pay for the online subscription. It didn't matter which one we used the system just sat at the "Please wait." screen. We let it sit there for easily 5 minutes with nothing happening. I know the network connection works because we can listen to the Pandora app. As a side note, he is also running the most recent firmware; I updated it this afternoon as soon as the message popped on the screen.
I tried searching the forum, but all I really found was talk about the XML not updating or updating randomly.
Did SiriusXM kill the Yamaha app when they redesigned their website a few months ago? Or does it take an obnoxiously long time the first time you log in? Or might there be something else?
If Pandora and IP Radio work then your network is fine and it's a SiriusXM/Yamaha problem. I don't use the service.
post #872 of 1085
Originally Posted by JoeKustra View Post
Learn how the Scene buttons work.
hmmmm....So the Scene buttons can be incorporated into the Harmony remote button command???
post #873 of 1085
I don't have a Harmony. I hear they are very good. They may have a thread on this forum. I'm glad you were able to get the Scene buttons to work for your switching inputs. I wish we had more of those white buttons.
post #874 of 1085
Then one thing at a time. Your front speakers have a documented frequency response. If the lower limit is 60Hz or 80Hz, I would consider them "small". If it's 20Hz, I would consider them large.
Please note: most setup menu options have an up arrow that means more data can be found by using the remote "up". Please check those options.
What is reality? I know I can't answer that one.
heres how it works apparently:
setting sub to 'use' allows you to choose large or small front mains. if you set subwoofer to none, you arent able to choose small front mains. it will default to large.
once you choose 'use' subwoofer, then you can select small front mains. but if you choose 'use' subwoofer, and keep the fronts as large, your sub(s) will not activate unless you turn on extra bass.
seems to be this is important info for people with large mains that want their subs to work as well.
post #875 of 1085
Sounds logical. Anyhow, my speakers didn't come in a box with a sticker stating they needed a subwoofer. I bought them for their high end and left them set to large after YPAO. My sub works wonderful, and it is set to "use" at 0.0 db. Most of my content does not have the LFE signal. I like the extra bass. Works for me.
post #876 of 1085
My speakers didn't have a box, let alone a sticker. I was just trying to understand how it all worked. I figured it out. Thought it would be helpful to others to let them know if they dont turn on the extra bass, they wont be getting anything out of their sub since simply setting them to large isn't enough
post #877 of 1085
The LFE signal will make the subwoofer activate. But that's a content issue.
post #878 of 1085
Not sure if you are agreeing with me or not. Are you saying you can get subwoofer activity with the mains set to large and with extra bass off?
post #879 of 1085
I have been trying to do a firmware update on my unit and it gets to 100% but just sits there. I've waited over a half hour and still just sits there. Is there something I am doing wrong or does it just take a lot longer to complete? Thank you for your help... Ann
______________
RX-V867 Firmware Update
Thanks to the 867's networking feature the firmware update is much easier than performing it on the 667. That said... the 867 owners manual doesn't do a very good job of explaining the specific process. After flipping back and forth through the owners manual to determine the necessary steps I decided to write down the step by step instructions to save myself from future aggravation.
NOTE: During this firmware update process don't bother attempting to use your TV or the on screen display. Although there may be information displayed... you'll be performing all the firmware update steps via the display on the front of the receiver. Also... although you may have a functioning wireless network... for this firmware update I'd suggest using a hardwired internet connection just to play it safe.
FIRMWARE UPDATE STEPS FOR THE YAMAHA RX-V867
Perform all the following steps on the front of your receiver
1) Turn the 867 OFF - NOTE: When the unit is off, this is what Yamaha calls Standby Mode... (only the red LED on the left side of the unit will be glowing)
2) With the unit Off... on the front of the receiver, press and hold in the STRAIGHT button, then... while holding the STRAIGHT button depressed... power the unit on. (i.e, press the button labeled MAIN ZONE).
.... Almost immediately the receiver display will show ADVANCED SETUP. (watch closely as the advanced setup message is only on the display for a few seconds before it will change to SP IMP. 8ohmMIN)
3) Rotate the PROGRAM selector knob until you see FIRM UPDATE in the receiver display
4) Press the INFO button on the front of the receiver. - Almost immediately the receiver display will show NETWORK UPDATE, ... at this point (if your unit is downlevel) the firmware update process will begin.
NOTE: Be aware the Firmware update takes about 16 minutes. So be patient. DO NOT power down your receiver during the update process. (in fact, just to be safe, I wouldn't do anything with the setup during the update process.)
When the firmware update is finished the display will show UPDATE SUCCESS...followed by the message PLEASE POWER OFF
That's it... after you power the unit off and back on you will be at the current firmware level.[/quote]
post #880 of 1085
He's saying that when there's a dedicated LFE track (that's the .1 in 5.1) it will go to the sub whether your mains are set to large or small.
But as many have said, the best advice is always to set your main speakers to small. Then you don't need extra bass you just have to set a crossover frequency that's appropriate for your main speakers, and both your mains and sub will be used (for the frequencies they can best reproduce). It's unfortunate that "small" sounds like it's insulting your speakers; they should really use a different term, or even remove the concept entirely and just leave the crossover frequency as a user-settable parameter.
post #881 of 1085
Thank you. You have explained it much better than I could. I think "reality" was brought up a few days ago. You seem to have a strong grasp of the concepts as used here. Thanks again.
post #882 of 1085
I disagree, if you have large speakers, let them be large as detected by the receiver. That's why you bought them... All my speakers are large. 99% of the time, your rears will do nothing, but the one time that they kick in for a explosion, you will notice.
If your speakers don't suck, then things will sound great, especially if you have a great sub. I think everyone should have a great sub, I have a 12" Velodyne, bigger is better!
post #883 of 1085
According to the manual "This unit can transmit or receive DSD signals via the HDMI jack."
Question: Where is the indicator that it is receiving the DSD signal from my SACD player via HDMI? Is there something I should be doing to make sure I am in fact getting this DSD signal?
I know my Pioneer DV-610AV is DSD compatible.
Any help would be appreciated.
post #884 of 1085
Three actually:
First is OSD->Information->Audio should say DSD (even on 2.0)
Next is on the TV: bottom left should say Super Audio CD
And on TV: upper right should say DSD Multi.
If you get track information on the screen your DVD Blu-ray is better than my Sony S570.
post #885 of 1085
Three actually:
After messing with this I could finally get it to display DSD but run into another problem maybe you would know about.
My SACD player, and Yamaha for that matter, is used only for audio and I normally do not have the HDMI out of from the Yamaha going into my monitor.
When I do have it plugged in I can get the Yamaha to display DSD. But when I do not have it connected it will only display PCM.
Any idea why it will only display DSD when connected?
post #886 of 1085
A bug? I assume you mean turned on and plugged in, not just plugged in. Maybe an active HDMI switch box might fake it out. Is CEC - HDMI Control disabled? Just guessing since I still show DSD on the front panel with the TV off.
post #887 of 1085
Yeah turned on and plugged in. I can be playing a SACD and the Yamaha shows DSD but the moment I switch the HDMI Input on my monitor from the Yamaha to my say Desktop it will cause the SACD player to stop. When I start the SACD player up again it will only display PCM on the Yamaha.
I am wondering if that is more of problem with the Pioneer now. I'll check out some other forums.
Thanks for the help though I appreciate it. Was going crazy for a while.
post #888 of 1085
I swapped out the Pioneer with a Sony BDP-S370 and sure enough DSD displays properly and works fine. Looks like the problem is with the Pioneer DV-610AV.
I can even switch the HDMI sources on the monitor and Sony continues to play. At least its good to know the Yamaha works properly.
post #889 of 1085
I have this login problem as well and it started just a month or two ago. All of my other streaming services run fine. My bigger issue is that some of my Sirius channels will be randomly unable to play. That is, I will be listening to one channel, select another, and the system will try to connect and buffer but will ultimately say that it cannot play the station. This never happens on most of the channels I select but seems to happen quite often on the 80's on 8, Spectrum, and 1st Wave channels.
I swapped out my ethernet cables and tried a new ethernet switch box and those things seemed to temporarily help. It goes back to having problems pretty quickly however.
I am going to do some more trouble shooting but this seem pretty clearly to be related to the change that Sirius/XM made in their streaming system login and online look and feel a few months back. Surely, they have done something that the Yamaha receiver does not like. I am hoping for an upgrade to fix this but I doubt if the service is high enough of a priority for them to work on. I will try to get in touch with Yamaha support in the next few days to see if they know anything.
post #890 of 1085
Harmony setup with the 867 question...
I often need to switch the AudioIn to another source and leave Video alone. Is there a way to make a sequence on Harmony to do this??? Maybe I am overlooking the obvious??
Depends on which Harmony Remote you have, but what I did for mine to edit settings that aren't on the main buttons of the harmony is to add those settings onto the extra buttons portion, usually the small graphic display on the newer Harmony remotes. You may have to use page 2 or page 3 if you already have page 1 filled up. If the setting can be selected directly (like Audio Input 4) from the Yamaha remote, you can simply add that command to page 2( or 3). If the setting has to be scrolled through (like Audio Input ?) then add that and you'll simply have to press the button to scroll through until you get to the right input.
The Scene buttons do this for you on the Yamaha and are customizable, but the Harmony can do the same things. If you want to make a sequence to do a few steps, the Harmony lets you build that too. Go to Edit Settings for the activity and select "I want to add more control" (or something close to that) and that will allow you to build added commands into the sequence for a particular activity. Its there, you just gotta find it.
post #891 of 1085
Hi everyone, I tried searching, but honestly I'm not even sure what to search for. I recently bought the RX-V867, and I have a Samsung LCD TV (LN550A), and a Samsung BD player (I forget what model), w/ a Verizon cable box hooked up. I believe I have them each hooked up properly, as I have the TV hooked up via HDMI (TV HDMI In, Receiver HDMI Out), and the BD player is hooked up via HDMI (BD HDMI out, Receiver HDMI In1)...and the cable box is hooked up into HDMI In2. The TV functions properly, as I can watch TV with the receiver either on or off, however I can't turn on my BD player without it automatically turning on my receiver. Also, sometimes when I shut the receiver off after it being on, and go to turn on my tv, the TV doesn't recognize the cable input...so I have to turn the receiver back on and off. Sorry if this sounds confusing, but I'm by no means an expert with A/V. Any feedback is much appreciated. Thanks in advance.
post #892 of 1085
You have learned that CEC (HDMI Control) works ok to turn on inputs but sucks when you turn something off. Perhaps someone with your hardware can give you better help. I have CEC (HDMI control) disabled on everything. My problem I guess, since I have some non-CEC devices connected. So I do what humans have done for while: fight gravity and turn things on manually. I call it exercise.
post #893 of 1085
Hey everyone,
has anyone used the v867 dual outputs to output from a comcast hd box?
post #894 of 1085
Originally Posted by eliteconcept View Post
Hey everyone,
If you are missing data from one or more HDMI outputs, cycle the outputs with the remote's HDMI OUT button.
post #895 of 1085
Thanks for the suggestion. After some research I found that my comcast set top box only allows 2 downstream devices, which I had before I tried to hook up a second device to the hdmi out 2.
Comcast suggested a couple other HD boxes that will allow 3 devices downstream. I'm going to try one of those.
On another topic, my ps3 worked with the dual output, no problem. However I did not get any sound on my second display device.
Any thoughts on that problem?
post #896 of 1085
Was this only because of hooking another device to HDMI out2 of the 867?
Something sounds weird, if your running your comcast HD box to the cable box HDMI input on the 867, why should it matter about 2 or 3 devices down stream, when the reciever is doing the digital switching? Sounds like a faulty HD cable box, as it really should not matter when using the dual HDMI outputs of the 867....
The Dual output HDMI of the 867 shows the same image on both HDMI out's displays, so why would this even be an issue, would love to hear this one.....
As I understand how dual HDMI works, which was the reason behind it, be able to watch two displays with the same output, like having a party and watching the superbowl, and seeing it on two seperate displays, but when you change the channel on the HD cable box, both screens change at the same time.
I would call Yamaha direct, as this does not make any sense to me ( but as I've got older, more and more things seem not to make much sense too, LOL )
I will call Yamaha and get their response to this as well.....
post #897 of 1085
THanks for your response. I thought the same thing as you did, but apparently this is not the case in reality. As I said the PS3 works fine except for no audio on display #2, which is odd.
I do think I'll call up yamaha and see what they say at the very least about no audio.. and ask them about the hdcp issue.
I'll feedback when I hear what they say
post #898 of 1085
Just spoke with support. The guy said that my issue may be that the hd box can't push out the signal with enough power, so it cuts out both displays all together. He stated the hd box should not know that there are 2 devices hooked up to the reciever. He did suggest that it could be a funky hd box, or that a different HD box may work. He also stated that my PS3 dual out with no sound on my second display may be the same issue. The ps3 may not have enough power to push out audio and video to two devices, so it just cuts out the audio. He did suggest to try setting the ps3 audio settings to automatic.
post #899 of 1085
Sounds good, I do know the special buttons to access the advanced settings in the comcast HD box, where you can adjust a few settings, but I like your previous idea of using a " newer " HD box, a try, and see how it goes, with a situation like this, I'm still against using the second HDMI out of any receiver for this reason as in reality you really should not need it, if I want multiple displays showing the same source, I built a HTPC with a Ceton HD tuner card, and I run 4 extenders, and watch the same on many sets, and the receiver has an input just for that.
My current comcast HD box is having massive HDMI issues and I have to exchange it for a newer one with-out DVR, would be interesting to see which models are their newest ones w/o dvr.
post #900 of 1085
The issue revolved around the username my father-in-law had. It was an XM one prior to the merger. We had his username changed from his email address, which was 22 characters, to his name, which was 15 characters, and it works fine now. I found a thread in a different forum that mentioned the username length issue. I wish I could find it again to link here, but I can't. If I remember right, the username has to be 20 characters or less. Hope this helps you out.
