AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › The Official Panasonic GT30 Settings Thread
The Official Panasonic GT30 Settings Thread - Page 40
post #1171 of 1241
Well - I do have a bright room and during the Sunday games there is a lot of ambient light in the room. I've also dropped a Darbee Darblet into the Video chain so I am doing a lot of experimenting with both the GT30 settings; Custom/THX/Vivid as well as with the Darbee settings. I'm still within my 30 day return window on the Darblet so I have some work to do before I make that decision. Thanks again for your calibration postings.
Anyone else with the GT30 utilizing a Darblet?
post #1172 of 1241
Using a Darblet on my GT30 and using Dave_O's settings. Very impressed with the detail provided by the Darblet.
post #1173 of 1241
What Darbee settings are you using - I've been playing around with HD & Gaming at 45-55
post #1174 of 1241
In that circumstance, Vivid would be great for the NFL ST games.
I found that it's akin to using an excess setting of "sharpness"; the video becomes too edgy for my taste.
post #1175 of 1241
HD only but like you between 45 and 55. Mostly 55.
post #1176 of 1241
Originally Posted by D1v1deByZero View Post
Does that Sony not have an HDMI color space setting for RGB? If so, that is what I would use.
My player does have the option of setting it to RGB. Anyone else agree that I should set my color space on the blu ray player to RGB? What's the difference between RGB and 4:2:2 or 4:4:4?
post #1177 of 1241
Set it to auto, the GT30 will tell the player what color space to use then.
post #1178 of 1241
I've played with several different settings posted here and no offense to anyone but the ones Dave_O did back around 12/4/12 to me just cannot be beat. The THX settings alone are still amazing. The only difference I did was change the temp to 'Warm 1" instead of the Warm 2 in both Custom and THX. It to me provides a happy medium between Normal & Warm 2. In Custom for Mid Panel Brightness, I also used a +5 in Black Extension. In his chart he has it at "0" but makes a note (+10 per D_Nice's Advice).
I am looking for some settings for say sports events in mid/medium lighting conditions with tweaks to the vivid/game mode
post #1179 of 1241
Yes, I do agree . . . and in fact, were the starting point for my settings.
Yes, the chart shows the main differences between our settings. I still believe in the use of AGC and don't like the "amount" of color (49 vs 32) setting used. Note these are for GT30 with the V2.1 patch.
Edited by JForge - 1/12/13 at 11:59am
post #1180 of 1241
For sports (NFL Playoffs)
Vivid - HDMI Content Graphics
Color Temp - Cool2
Contrast-80
Brightness-58
Color - 56 (with graphics on you can have the color all the way up without red push,with HDMI OFF you have to have color around mid 30's)
Tint - 0
Sharpness - 29
post #1181 of 1241
Must need sunglasses for those settings
post #1182 of 1241
When you do service menu adjustments does it effect the custom picture settings? Reason I ask is because I had a pro calibration done by value electronics and I'm not happy with their custom settings for day viewing there is way too much red in skin tones so if I use different custom settings from someone else on here would it be fine since I'm assuming they did sm adjustments, their thx calibration for night is fine.
Edited by captaink5217 - 1/17/13 at 7:22am
post #1183 of 1241
When SM adjustments are made, they COULD affect the CUSTOM mode if the SM changes are made to settings that are in the 'custom' mode and the proper "color".
If you understand that statement, then you can make changes without an "oops"! If you don't, (sorry, I suspect you don't!), then you should stay away from making any changes.
If you do decide to make changes, be sure to write down the original values so you can go back to them if needed!!
In my signature, under the "VIVID" mode settings, please read the "*** How to access the xxGT30 Service Mode***" procedure. This procedure shows how to make changes for JUST the VIVID mode specifically to the "WARM" color settings . . .ONLY! Again if you understand this, have at it. smile.gif
One last point; my VIVID settings do make SM changes but my CUSTOM settings do not.
post #1184 of 1241
Did captaink5217 have the 2.1 patch applied? The way I understood it that would help with the red skin tones in Custom mode
post #1185 of 1241
Yeah, value electronics does all the updates prior to calibration, I just checked I'm up to 2.2
post #1186 of 1241
This info on these forums will get you into trouble . . . I'll try to help!
If you (captaink) did not do the Panasonice V2.1 update MANUALLY (ie did it yourself!), then your TV does NOT have the V2.1 patch installed. Sounds confusing but it's not.
Update: Didn't know your TV was pro-calibrated and the V2.1 patch was installed by the calibrator.
The TV will update itself if you have it connected via WiFi but it does using Panasonic's default (as delivered) firmware. You can update the TV yourself or some calibrators will do if they recommend that your TV would be better calibrated with the V2.1 patch installed. You can do-it-yourself by downloading the patch and placing it on an SD thumb-drive to install to the TV.
Hope that's clear. . . .
Edited by JForge - 1/18/13 at 9:47am
post #1187 of 1241
The "value electronics" does update the TV's firmware configuration but it does using Panasonic's default (as delivered) firmware. Again the ONLY way you can get the Panny V2.1 patch is to do it yourself via SD thumb-drive by downloading the patch and installing it.
Do I have this correct...the 2.1 patch is the one from Panasonic that brightens things up (luminence) and helps the red skin tones in Custom, and installs with a SD card or thumbdrive and is irreverseable, whereas the 2.2 Update is a regular type of firmware update you install over WiFi? I take it there was no update for the 2.1 patch?
I downloaded the v2.1 Patch a while back and chickened out about installing it (I don't like the word "irreverseable"), but am not totally satisfied with the PQ over Comcast, even the HD channels could look better, cleaner. I calibrated it with Dave_Os settings, tried a couple other suggested ones, and tried it myself using the WOW disc, but couldn't seem to make the set look the way I thought it should look. I think I may be ready to try the patch (I think).
post #1188 of 1241
You got it all correctly! Cheers!
I'm told that AFTER you install the V2.1 patch, you can let the system update and install a V2.2 update (nothing to do with chroma). Personally, I DID NOT let the TV update to V2.2 after I installed the V2.1 patch. As I understand, that V2.2 update is for the 'frills'.
I downloaded the v2.1 Patch a while back and chickened out about installing it (I don't like the word "irreverseable"), but am not totally satisfied with the PQ over Comcast, even the HD channels could look better, cleaner. I calibrated it with Dave_Os settings, tried a couple other suggested ones, and tried it myself using the WOW disc, but couldn't seem to me the set look the way I thought it should look. I think I may be ready to try the patch (I think).
I originally felt the same way but my CMS was so bad, that I had to try something. The picture quality today, is great and I'm totally happy with the installed the V2.1 patch.
post #1189 of 1241
I'll have to look, but I think I already installed the 2.2 Update, so I'll re update after the patch.
I originally felt the same way but my CMS was so bad, that I had to try something. The picture quality today, is great and I'm totally happy with the installed the V2.1 patch.[/quote]
Sorry for such a noob question, but what's CMS?
post #1190 of 1241
My understanding is that value electronics does have the 2.1 patch on a flash device so they could calibrate correctly. The update to 2.2 was done by me after I had the set up and going.
post #1191 of 1241
When you get a new A-Board installed from a Panasonic for FBR issues, does this new board have this update already installed?
Or do I need to do this again, like I did to my old board?
post #1192 of 1241
Since the 2.1 patch was intended for use by professional calibrators I don't think it will already be installed on your new board. I 'd do it again.
post #1193 of 1241
I went with Jforge settings but with warm 1 instead of normal temp I thing the pro calibration I paid for fixed the warm temp setting so that might be why normal on mine looks a little too blue but warm 1 looks right for custom, I still use the thx pro calibration for night that value electronics did plus I saved my settings they did on custom for day just in case I want to put them back.
post #1194 of 1241
Value electronics uses pro calibrators dnice, Ed Johnson and such and I believe they apply the 2.1 patch for them. Actually they did just tell me that they did put 2.1 patch on my set.
Edited by captaink5217 - 1/18/13 at 8:56am
post #1195 of 1241
After you do the V2.1 patch, the TV will update itself if you have it connected via WiFi.
CMS stands for Color Management System.
post #1196 of 1241
I went with Jforge settings but with warm 1 instead of normal temp I thing the pro calibration I paid for fixed the warm temp setting so that might be why normal on mine looks a little too blue but warm 1 looks right for custom.
If you have read some of my earlier posts, my 55GT30 had a red-green (yellow) tint so using "normal" temp setting neutralized it . . otherwise I would have used "warm1".
. . . .plus I saved my settings they did on custom for day just in case I want to put them back.
Edited by JForge - 1/20/13 at 11:55pm
post #1197 of 1241
The whole process of the 2.1 Patch with screen shots and instructions can be found here....
http://panasonic.jp/support/global/cs/tv/download/pro/down_pro.html
post #1198 of 1241
I'm definitely familiar with sm adjustments, I've done them on my older panasonic plasma, when you say color it's color temp, when you make sm adjustments it only effects changes that color temp ie warm sm adjustments only effect warm and not normal or cool. So I'm very comfortable in panasonic service menus
post #1199 of 1241
About using the patch...can I use a flash drive or does a SD card work better, and when I format it, or an SD card, do I choose NTFS or FAT32?
post #1200 of 1241
I used a 2GB SD card formatted to FAT32. Worked fine.
