AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › The Official Panasonic GT30 Settings Thread
The Official Panasonic GT30 Settings Thread - Page 42
post #1231 of 1248
Originally Posted by Mean Gene View Post
I have seen several different versions of his settings. Could someone please direct me to his "final" settings? Thanks!
My settings are in my signature . . . and I try to keep them updated. Haven't made a change since my TV has finally stabilized.
Being critical my best settings are THX for a darkened room. Even I like them but I still use the Custom settings b/c they have a little more pop in the video.
post #1232 of 1248
Originally Posted by moxie1617 View Post
If you find his posts I believe they are linked in his signature. I access from an iPad and don't see signatures.
I'm sorry, I meant Dave_O's settings. I am trying to decide between his and Jforge's as my final and never adjust again settings. Thanks everyone.
post #1233 of 1248
Thanks JForge, I have tried your custom settings before and will try these as well. Thanks!
post #1234 of 1248
Check out this post for a comparison of Dave_O's and my settings . . . in chart form here
post #1235 of 1248
Until I get to a PC I won't be able to find Dave_O's post with the settings, search using the iPad interface sucks. However, you may want to take this into consideration. Those settings by Dave_O are now two years old and jForge's are more recent and would probably be better with our well aged panels. If I had the guts to use the service menu I would like to try his, plus he passed the color test with (no pun intended) flying colors.
post #1236 of 1248
Thanks Moxie and JForge, I will use the chart as my final comparison and settle on the settings.
post #1237 of 1248
so do you use your custom settings on a regular basis? in your signature you seem thoroughly excited about your vivid settings, do you believe the custom settings are better still? I do have a normally lit room, no direct window, but moderate sunlight. I currently use Dnice's custom settings, they are very similar to yours but use 47 color, 0 agc, +1 tint and pro settings -3,0,0,+1,0,0,-1. a year ago these settings seemed to be prefered by the majority over daveo's settings, what's your opinion on this set up?
Edited by madkong - 5/6/13 at 6:00pm
post #1238 of 1248
Without calibrating the TV, the settings that I have or Dave_O has or what you have are modified are by definition, the best for YOUR viewing. IOW, the settings are very TV dependent and from what I seen, they tend to be different b/c each TV is different. As you read, my TV seems to push green, others push blue, some push red.
My settings or those of others, will get you into the ballpark where you can then adjust them for peculiarities of your TV. There are no right or wrong settings.
I happened to 'play' with my three main settings (Custom, THX and Vivid) and was not pleased with my Vivid settings; the picture was "ugly"!!! I mainly use the Custom, my main preference and THX, my second preference.
post #1239 of 1248
ok, I get what you're saying. ya I tried a few settings and custom definitely has the best picture on my tv, that's why I didn't want to do the s/m adjustments unless you strongly believed it was better. my tv pushes slightly more red, that being said I like j forge's settings because it uses agc which I love but could never get the saturation quite right due to the red push. jforge's settings and some minor tint and pro setting adjustments later, best picture I've had to date!
post #1240 of 1248
Originally Posted by madkong View Post
ok, I get what you're saying. I like j forge's settings because it uses agc which I love but could never get the saturation quite right due to the red push. jforge's settings and some minor tint and pro setting adjustments later, best picture I've had to date!
Tnx alot . . glad you like the Custom settings, modified for your TV. That's the way it s/b done.
Yes, I too like "AGC" . . . b/c I think that it allows you to "see" background black detail simultaneously with a high contrast foreground. W/o AGC, you seem to loose some of the background detail.
Edited by JForge - 5/7/13 at 11:50am
post #1241 of 1248
I agree especially in movies where there can be alot of dramatic lighting changes from one scene to another. Thanks again, you da man!
post #1242 of 1248
Hi All, I have the 65" GT30 model paired up with a PS3. I am only able to get 1080i to the set and not 1080p. Would that be something to try a different HDMI Cable or is this just normal for the set? I have budget HDMI cables that I've had for quite some time.
post #1243 of 1248
freemeat, are you using a REALLLLLY OLD HDMI cable?
Order something for $20 or so on Newegg.com then.
Triple Shielding etc, 99% copper,e tc. Just don't buy Monster for the sake of penalizing them for all their years of BS.
post #1244 of 1248
Maybe a 3 years or so. So the hdmi could be limited in not passing 1080p and only enough for 1080i? Could be my old ps3 as well but I think it's fine . Guess ill give a new cable a shot, non monster wink.gif
post #1245 of 1248
I have an Triple Shileded GOOD cables with hdmi 1.4 capability. If your HDMI cable is like very LONG or on an extention, that's a problem too.
How Long?
What Brand if Any?
Thin PVC only cover or thick with a nylon sheath cover?
Make sure your PS3 isn't set to 1080i, lol.
I've only ever seen 1080i on COMPONENT.
I've seen 1080i out of a cable box, thats it.
Very odd.
post #1246 of 1248
How Long?
What Brand if Any?
Very odd.
Only a 6' cable. Some generic monoprice cable I think. PS3 is easy choose which output, you can manually select all the output resolutions and works fine with all aside 1080p.
Yeah it is odd. I think I'll order a cable and see if it works, otherwise 1080i it is. It still looks great so I'm not that concerned.
post #1247 of 1248
Freemeat, are you running 1080p yet fella?
post #1248 of 1248
So, is there a Receiver in the middle here? Or a multiswitch?
